Cisco 2911
abbasali5
Cisco 2911 is going to EOL in December.  I have an existing 2911 that I would like to keep it for one of my branch offices that doesn't require any immediate upgrade.  I would like to install a Service Module and Windows Server OS to run some local services such as windows print server/DHCP server etc for small number of users not more than 20.
Trying to find out the CPU and memory requirements to add service module into the existing Cisco 2911 series router.
Philip D'Ath
Check out the part codes starting with UCS, and note the ones saying they are not compatible with the 2911.
http://www.cisco.com/c/en/us/products/routers/2900-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
Philip D'Ath
