cisco 2948G Switch
ray_stone
Level 7
Level 7
Hello Experts,
We just procured cisco 2948 switch which details stated below:
WS-C2948 Software, Version NmpSW: 8.4(11)GLX
Copyright (c) 1995-2006 by Cisco Systems, Inc.
NMP S/W compiled on Apr 27 2006, 12:46:44
GSP S/W compiled on Apr 27 2006, 11:47:52
System Bootstrap Version: 6.1(4)
Hardware Version: 2.6 Model: WS-C2948 Serial #: JAE062503TF
Mod Port Model Serial # Versions
1 0 WS-X2948 JAE062503TF Hw : 2.6
Gsp: 8.4(11.0)
Nmp: 8.4(11)GLX
2 50 WS-C2948G JAE062503TF Hw : 2.6
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65536K 36879K 28657K 12288K 5930K 6358K 480K 289K 191K
Uptime is 0 day, 0 hour, 2 minutes
Please confirm its a L2 or L3 Switch. Also it has CAT OS installed already so please let me know if it can be upgraded into IOS. If not, do we need to upgrade into other CAT OS version that you would recommend. Also I'm not good in CAT OS conf and its a nex box switch so please help me in this as well. The switch is connected via console cable and the enable command can run but not config t. It would be better if someone provide the commands step by step.
6 Replies 6
Leo Laohoo
It's a Layer-2-only switch.
It's CatOS and you can't upgrade to IOS.
"config t" doens't work with CatOS.  It's a "set" command and the command is automatically saved.
ray_stone
Level 7
Level 7
Thanks LEO for your quick reply. Can you please tell of what commands of IOS doesn't work on CAT OS. I need to setup trunk port, creating VLANS and other basic config so the Cat OS commands are same as IOS. Please confirm and also highlight some other concerns which may help me in future.
ray_stone
Level 7
Level 7
Thanks again.
Let's suppose I create 3 VLANS on switch and the switch will have one trunk port connecting to firewall where the firewall connected port has sub interfaces created. Also I create VLANS on ESX host which will connect with switch and switch port will be trunk. Now my question is if I use two Ethernet ports of ESX host and connect with two switch ports by configuring trunk ports so would it work as a port ether channel where the bandwidth will be doubled or we would require to configure ether channel on switch. Please confirm.
it has been more than 6 years sinve ive configures a 2948G
this model is very old and the links ive posted should have examples on how to configure etherchannels on a 2948G
