Cisco 2950 - 3350 Trunking issue - Port not lighting up
CSCO11511067
Hi There,
I have two switches I am trying to connect a 2950 and a 3350. I have a crossover cable connecting them from fa0/24 to fa0/24 setup as a trunk,
however they won't connect and the port on both switches is down, (e.g no port light coming on on switch)
here is some show commands from both switches.. does anyone know where I am going wrong.. thanks in advance
2950#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
Vlan1                      192.168.0.11    YES NVRAM  up                    up
FastEthernet0/1            unassigned      YES unset  up                    up
FastEthernet0/2            unassigned      YES unset  down                  down
FastEthernet0/3            unassigned      YES unset  down                  down
FastEthernet0/4            unassigned      YES unset  down                  down
FastEthernet0/24           unassigned      YES unset  down                  down
2950#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16, Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
Remote SPAN VLANs
Primary Secondary Type              Ports
2950#sh run
Building configuration...
Current configuration : 1278 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 2950
enable secret 5 $1$JKXw$gcYpfOaSQRiQqcCuVF5371
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
switchport mode access
interface FastEthernet0/4
interface FastEthernet0/24
speed 100
duplex full
interface Vlan1
ip address 192.168.0.11 255.255.255.0
ip http server
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
2950#
3350#sh vlan
1    default                          active    Fa0/1, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10, Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16, Fa0/17, Fa0/18, Fa0/19, Fa0/20
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24, Gi0/1, Gi0/2
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
Remote SPAN VLANs
3350#sh ip int brief
Vlan1                      192.168.0.12    YES NVRAM  up                    up
Vlan200                    unassigned      YES NVRAM  down                  down
FastEthernet0/1            unassigned      YES unset  down                  down
FastEthernet0/2            unassigned      YES unset  up                    up
GigabitEthernet0/1         unassigned      YES unset  down                  down
GigabitEthernet0/2         unassigned      YES unset  down                  down
3350#sh run
Current configuration : 1728 bytes
version 12.1
no service pad
hostname 3350
enable secret 5 $1$ojzz$X.gjyIj/4JDGAUDXYP5ie1
ip subnet-zero
ip routing
no ip address
no ip address
no ip address
switchport mode trunk
no ip address
duplex full
speed 100
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 192.168.0.12 255.255.255.0
interface Vlan200
no ip address
ip classless
ip http server
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
3350#
I am using are cross over cables and that may be why it is not working....
Without TDR, it's hard to determine.
Loop the cable:  Plug the cable in one port (access) and plug the other end to another port of the same switch (access).  If the ports light up, you have a good cable.  If the ports don't light up, then you've got a bad cable.
10 Replies 10
Karthick Murugan
Hi Jessse,
In 2950, auto-mdix is not enabled by default. Can you try configuring auto-mdix under the interface and check the status?
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
Hi  Karthick,
I had a look under the interface however I don't appear to have any command for mdix-auto?
2950(config-if)#?
Interface configuration commands:
  arp                 Set arp type (arpa, probe, snap) or timeout
  bandwidth           Set bandwidth informational parameter
  carrier-delay       Specify delay for interface transitions
  cdp                 CDP interface subcommands
  channel-group       Etherchannel/port bundling configuration
  channel-protocol    Select the channel protocol (LACP, PAgP)
  default             Set a command to its defaults
  delay               Specify interface throughput delay
  description         Interface specific description
  dot1x               Interface Config Commands for 802.1x
  down-when-looped    Force looped interface down
  duplex              Configure duplex operation.
  exit                Exit from interface configuration mode
  fair-queue          Enable Fair Queuing on an Interface
  help                Description of the interactive help system
  hold-queue          Set hold queue depth
  ip                  Interface Internet Protocol config commands
  keepalive           Enable keepalive
  lacp                LACP interface subcommands
  load-interval       Specify interval for load calculation for an interface
  logging             Configure logging for interface
  mac-address         Manually set interface MAC address
  macro               Command macro
  mls                 mls interface commands
  mvr                 MVR per port configuration
  no                  Negate a command or set its defaults
  pagp                PAgP interface subcommands
  random-detect       Enable Weighted Random Early Detection (WRED) on an
                      Interface
  rmon                Configure Remote Monitoring on an interface
  shutdown            Shutdown the selected interface
  snmp                Modify SNMP interface parameters
  spanning-tree       Spanning Tree Subsystem
  speed               Configure speed operation.
  storm-control       storm configuration
  switchport          Set switching mode characteristics
  timeout             Define timeout values for this interface
  transmit-interface  Assign a transmit interface to a receive-only interface
  tx-ring-limit       Configure PA level transmit ring limit
  udld                Configure UDLD enabled or disabled and ignore global UDLD
                      setting
2950(config-if)#
The reason why MDIX is not enabled by default on 2940/2950/2955 & 3550 is because MDIX is NOT SUPPORTED on this platform.  MDIX support started appearing with the release of the 2960, 3750 and 3560 switches.
duplex full
speed 100
Remove these two lines from either switches.
Rashid Thompson
Jesse,
Have you tried a straight through cable? Also I would change the 2950's interface FastEthernet0/24 to switchport mode trunk.
CSCO11511067
Ah yes, sorry, I noticed that when I posted, I did change this and both ends are indeed trunks.
I tried removing duplex full / speed 100 on one side and then both sides, this seemed to make no difference
Ive tried a straight through cable and multiple other cables
I'm starting to think that none of the cables I am using are cross over cables and that may be why it is not working....
I have lots of cables from isps etc for connection your modem to pc, but im starting to think  and on closer inspection of the cable that these are all straight through cables. and as these are like devices it should only work with cross over so maybe thats why the ports are failing to light up ?
3350#sh run
no ip address
2950#sh run
Good test, I was wondering... as I could plug my pc into the ports (which proved the ports were fine)
I just tried  looping multiple cables like you said by plugging them into access ports on the same switch and none of them are lighting up...
So from this it appears none of my cables are cross over cables....
ill source one tomorrow and try again.
thanks for your help!
Make sure they are cross-over cables.  MDIX is not supported so you won't get anything if you loop straight-through cables.
CSCO11511067
Got hold of a cross over cable, worked fine - trunk established.
lesson learnt! - will have to check to make sure im using correct cables in future!
Thanks for taking the time to rate our posts.
