Cisco 2950 No Flash: directory
RyCar66
Hi, I have a Cisco 2950 that only boots to switch: prompt.  When I issue the dir command, it returns:
List of filesystems currently registered:
         xmodem[0]: (read-only)
                 null[1]: (read-write)
I cannot mkdir (permission denied), I cannot do anything, basically.
How old is the device ? Chances are you have a corrupted onboard flash chip...
6 Replies 6
try and manually initialize the flash from the 'switch:' prompt.
To get to the 'switch:' prompt, telnet into the console port, hold the mode button and restore power. The boot loader should start.
At the switch: command line, enter: flash_init
I tried flash_init at the switch: prompt, I get:
Initializing Flash...
...no flash filesystems found.
can you try a dir after flash_init
You are correct, I opened the unit and discovered I accidentally hit a chip with my drill bit. Luckily we just upgraded and I have several of them to play with. This one is going in the trash.
Leo Laohoo
The correct syntax is "dir flash:".
