Cisco 2950 switch management IP change issue
Suresh Babu
Hi All,
I am planning to change the management IP (VLAN 5) to one of my Cisco 2950 switch, Here I am creating a new VLAN101 and assign new IP
When I am doing this VLAN 2 is going admin down.
Can somebody help me the reason behind, Is It switch limitation or am I doing any mistake.
Suresh
A layer2-switch like yours can only have one active IP-address for management. So when you add a new VLAN-interface with an IP-address the old int goes down. Works as designed. If it would be a layer3-switch, you could have multiple active VLAN-interfaces with IP-addresses configured.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Where does this Vlan defined?
Can U post sh run for the 2950 removing sensitive data if any?
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Thanks karsten for support....
