Cisco 2950 switch shows 20Mb
cssam
Cisco 2950 switch shows 20Mb..16MB for switch operaation IO and switch processes..what is rest of 4Mb used for?
cisco WS-C2950G-48-EI (RC32300) processor (revision J0) with 20957K bytes of memory.
Sampath Kumar.
6 Replies 6
Leo Laohoo
cisco WS-C2950SX-48-SI (RC32300) processor (revision K0) with 19912K bytes of memory.
You should be lucky.  I have less.
I noticed your switch image - Standard Image(SI). Our switch is EI.
Does anyone has idea how to calculate 20Mb. Normal 2950 has 16Mb of SDRAM as per documnent.
We have 4 Mb of memory extra.
Any update please...
Ganesh Hariharan
Sampath Kumar.
Hi Sampath Kumar,
Your switch has 20 MB of DRAM: cisco WS-C2950-48-EI (RC32300) processor (revision J0) with 20957 K bytes of memory.
Check out the below link for more information
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a0080169627.shtml
Hope to help !!
Ganesh.H
Remember to rate the helpful post
Hi i read the show version already...
But don't know why 20 Mb showing since document shows only 16Mb and even download software shows 16MB for 2950 switches.
8 MB Memory shared by all ports out of 20 MB of RAM. Rest of available memory 7.8 is allocated for system processes. Currently working IOS is limited features without crypto. It is normal utilization in your setup.
Cisco Catalyst 2950 Series Switches with Enhanced Image SW
http://www.cisco.com/en/US/partner/prod/collateral/switches/ps5718/ps628/product_data_sheet09186a00801cfb64.html
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_tech_note09186a00800fb9d9.shtml#memory
4 Mb extra is how come being utilized...
