Catalyst 2924M reset (or password reset) doesn't work
Kyujin Choi
Swtich is working condition. (POST test passed)
I could reset my 2 switches, but other 2 switch coudln't.
I held "Mode" button until fa0/1 light is off. it goes to below section (swtich:)
The problem is this switch was treaked because flash:config.text flash:config.text.old      (flash command doesn't work, i can't even see command list from help command)
I did lilke this
- go to (switch:) mode (holding mode button until fa0/1 is off)
- flash_init (it works)
- dir flash:
If you have any idea, it will be appreciated.
2    -rwx  1811155   <date>               c2900xl-c3h2s-mz.120-5.WC13.bin
3    -rwx  316       <date>               env_vars
4    -rwx  796       <date>               vlan.dat
5    -rwx  2740      <date>               config.text
  - I can't delete or rename config.text because of permission.
  - normal password reset method doesn't work  (flash:config.text)   I guess previous owner of switch, he treaked this.
Password:
% Access denied
Username:
C2900XL Boot Loader (C2900-HBOOT-M) Version 12.0(5.3)WC(1), MAINTENANCE INTERIM
SOFTWARE
Compiled Mon 30-Apr-01 07:34 by devgoyal
starting...
Base ethernet MAC Address: 00:09:43:01:36:80
Xmodem file system is available.
The system has been interrupted prior to initializing the
flash filesystem.  The following commands will initialize
the flash filesystem, and finish loading the operating
system software:
    flash_init
    load_helper
    boot
switch: flash_init
Initializing
flashfs[0]: 4 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 1817088
flashfs[0]: Bytes available: 1795584
flashfs[0]: flashfs fsck took 6 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
switch: load_helper
switch: help
           ? -- Present list of available commands
        boot -- Load and boot an executable image
         cat -- Concatenat
        copy -- Copy a file
      delete -- Delete file(s)
         dir -- List files in directories
  flash_init -- Initialize flash filesystem(s)
      format -- Format a filesystem
        fsck -- Check filesystem consistency
        help -- Present list of available commands
load_helper -- Load and initialize a helper image
      memory -- Present memory heap utilization information
       mkdir -- Create dir(s)
        more -- Concatenate (display) file(s)
      rename -- Rename a file
       reset -- Reset
       rmdir -- Delete empty dir(s)
         set -- Set or display environment variables
   set_param -- Set system parameters in flash
       sleep -- Sleep a specified number of seconds
        trap -- Cause a software breakpoint to occur
        type -- Concatenate (type) file(s)
       unset -- Unset one or more environment variables
     version -- Display boot loader version
switch: dir
List of filesystems currently registered:
               flash[0]: (read-write)
              xmodem[1]: (read-only)
                null[2]: (read-write)
                  bs[3]: (read-only)
switch: dir flash
unable to stat flash/: permission denied
switch: flash dir
usage: flash_init
switch: dir flash:
Directory of flash:/
1795584 bytes available (1817088 bytes used)
switch: flash:config.text flash:
Unknown cmd: flash:config.text
switch: help
         cat -- Concatenate (type) file(s)
        copy -- Copy a file
       reset -- Reset the system
switch: ?
        copy -- Copy a file
switch: dir flash:
switch: delete config.text
Are you sure you want to delete "config.text" (y/n)?y
File "config.text" not deleted -- permission denied
switch: dir flash:
switch: ?
        copy -- Copy a file
switch: dir flash:
switch: rename ?
usage: rename <old_name> <new_name>
switch: flash ?
usage: flash_init
switch: rename config.text config.text.old
rename: no such file or directory
switch: dir flash:
4    -rwx  796       <date>
switch: ls
Unknown cmd: ls
switch: dir
                  bs[3]: (read-only)
switch: elp
Unknown cmd: elp
switch: help
        copy -- Copy a file
       reset -- Reset
switch: cat config.text
config.text: permission denied
switch: set ?
switch: set
BOOT=flash:c2900xl-c3h2s-mz.120-5.WC13.bin
MAC_ADDR=00:09:43:01:36:80
MODEL_NUM=WS-C2924M-XL-EN
MODEL_REVISION_NUM=A0
MOTHERBOARD_ASSEMBLY_NUM=73-3425-10
MOTHERBOARD_REVISION_NUM=F0
MOTHERBOARD_SERIAL_NUM=FAB0609213N
POWER_SUPPLY_PART_NUM=34-0920-01
POWER_SUPPLY_SERIAL_NUM=PHI051005LH
SYSTEM_SERIAL_NUM=FAB0609P0ZM
switch: set_param
Burning parameters into flash parameter block:
    MAC address: 00:09:43:01:36:80
Reading parameter block...done.
Editing copy...done.
Writing parameter block...done.
Parameters burned into parameter block.
switch: dir flash:
6    -rwx  319       <date>               env_vars
switch: delete vlan.dat
Are you sure you want to delete "vlan.dat" (y/n)?y
File "vlan.dat" not deleted -- permission denied
switch: rename ?
switch: rename config.text oldconfig.text
switch:
switch:
switch: flash:config.text flash:config.text.old
Are you sure you want to delete "config.text" (y/n)?yes
switch:
buchholr
These devices are very limited when in Rommon mode.  You are typing "rename config.text config.old"  and "delete config.text."  I have never know this syntax to work when in Rommon.  Because the switch has no idea where to find the file, it gives you an unhelpful error message.  Try using "rename flash:config.text flash:config.old"  if you want to keep the old configs for some reason, or if you don't try "delete flash:config.text."
Hope this helps,
Rob
Ganesh Hariharan
Check out the below link for step by step procedure for password reset in 2900
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml switches
Hope to Help !!
Ganesh.H
