12-08-2006 08:59 AM - edited 03-05-2019 01:15 PM
Team,
I'm setting up a test environment with my Cisco 2950 Catalyst switch and need to configure one of its ports to run at 128k (to duplicate a connection at another office). Any ideas how to do accomplish this? I was thinking this had to do with rate limiting and not speed.
12-08-2006 09:08 AM
Yes,
You have to use polocing/rate-limiting on 2950 to acheive the same.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea5/2950scg/swqos.htm
HTH,Please rate if it does.
-amit singh
12-08-2006 09:12 AM
I will further research this and rate it. Thank you for the quick reply!
12-08-2006 09:23 AM
What's the switch model number. Paste the "show version" from the switch.
-amit singh
