cisco 2951 poe limitation for switch module ?
Dr.X
Level 2
Level 2
Hi , i have cisco 2951 router with switch module :
SM-D-ES3G-48-P
there are many poe devices connetced to the switch module .
the problem we face is , sometime the poe devices get down and up (flapping)
after investigatipon by command
show power inline police
i found the devices is getting about 60 Watt , and there is remaining power about 200 watt.
the question is , how to investigate and troubleshoot this issue ?
is there any limitation in the power for that platform ?
Leo Laohoo
Your description of the error message doesn't make sense.
Please post the error message.
Hi ,
thanks for reply
the issue is :
interfaces get down , then up
some times it still down and take long time to be up agian !!
exactly if i did shutdown , then no shutdown
thats the problem that we face !
sorry cant access the swith now , if i can i will post the config i have.
thanks for ur time
regards
