Cisco 2960-24TTL
roytan
Hi All,
I would like to check if my cisco 2960-24TTL switch can install firmware version 15.2(4)E6 or 15.2(6)E1?
https://www.cisco.com/c/en/us/support/switches/catalyst-2960-24tt-l-switch/model.html#~tab-downloads
Will there be any issue if i use firmware version from other Cisco 2960 models like 2960x etc to install onto Cisco 2960-24TTL?
Kindly advice , thanks.
Leo Laohoo
Not supported.
The "highest" version the plain/legacy 2960 can go is 15.0(2)SE train which 15.0(2)SE11 is the last-and-final version.
Yes, if forced to load an IOS which is not supported, the switch will go to ROMmon.
