Cisco 2960 L Port configuration issue
ashley_dew
We have recently installed a Cisco WS-C2960L-SM-24TS 15.2(6)E2b.
For reminder, the switch is configured on Web interface and cli on read only.
I have configured a port in access mode vlan 7 and then moved it to trunk.
The issue is that on cli, i can see both configuration on the interface and no way to clear it:
interface GigabitEthernet0/22
switchport access vlan 7
switchport mode trunk
On the web interface: it is trunk.
Hi Reza,
Thanks for your reply. The solution makes sense except the catalyst 2960 is a smart switch. The CLI is in read only and the configuration is done on web.
Since the switchport access vlan 7 does not impact the trunk operation, then there is no issue.
ashley_dew
Do anyone has had an issue?
Thanks and Regards,
Reza Sharifi
The additional command does not harm anything. Not familiar with the Web interface but on the cli, you can negate vlan 7 (no switchport access vlan 7).
Hi Reza,
