switch 3560e not loading IOS
Roldan
Visitor
Hi everyone:
I am trying to have a switch working(some one gave it to me as a gift, is a used switch but it was working). due to their company rules they deleted it before they gave it away.
I just want it to hard reset it so i can practice for my CCNA, but i fall into the below issues:
when i connect trough console it shows the below:
Switch:
when i try to reboot
switch: boot
Loading "flash:c3560e-universalk9-mz.150-2.SE8.bin"...flash:c3560e-universalk9-m
z.150-2.SE8.bin: invalid argument
Error loading "flash:c3560e-universalk9-mz.150-2.SE8.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
switch:
so i think that, c3560e-universalk9........ IOS was the one installed before, but i can not download that one so
i downloaded from cisco "c3560e-ipbasek9-mz.122-55.SE12.bin" to try to install that one instead(maybe is not the correct one, i am new in this)
but xmodem does not work, veryfied already the settings to 9600 b/p/s.
got after a few seconds a pop-up window that states "no response from remote system"
I check the flash and the below is shown:
switch: dir flash:
Directory of flash:/
2 -rwx 2282 <date> config.text
3 -rwx 5 <date> private-config.text
4 -rwx 3096 <date> multiple-fs
57662464 bytes available (9216 bytes used)
Can you please help me? i might be doing something wrong.
also the below is the version if it helps in any way.
switch: version
C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
Compiled Tue 27-Nov-12 00:23 by abhakat
Thank you all in advance.
Therese 3 Options you can do recovery.
Option1 TFTP, Option 2 USB, Option3 Xmodem
I have described Option1  and Option2 one of my blog.
http://www.balajibandi.com/2014/02/06/how-to-recover-a-cisco-switch-from-boot-loader-3560-3750/
xmodem you can follow below one :
https://www.freeccnaworkbook.com/workbooks/ccna/recovering-a-corrupt-cisco-ios-image-on-a-catalyst-switch
BB
16 Replies 16
thanks a lot, I will try it.
First of all, thanks for your response Kasun Bandara.
I can not even get into rommon mode, when i reboot the switch it does nothing but the below and really fast:
switch: boot
z.150-2.SE8.bin: no such file or directory
I tried to go into rommon as the manual instructions, but not working at all, still does the same every time I triy.
also tried this in normal(no rommon) mode, just to see what happens:
switch:
switch: dir bootflash:
unable to stat bootflash:/: no such device
Still nothing.
Thanks for your time.
balaji.bandi
here is the guide for your to fix the issue. you can download the image from cisco site.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html
BB
First of all, thanks for your response balaji.bandi.
I tried this already, but got stuck on step 4, I can not transfer the IOS to the switch, instead of starting the transfer i got the below:
On scree a pop-up window:
on switch CLI
switch: BB0BB0
Thank you for your time.
Roldan
Visitor
Hi again, I should have said that the label under the switch says the below:
TNY-WS3450x-3560X(A)
So I might have been trying to install the wrong IOS because i tried to set the "c3560e-ipbasek9-mz.122-55.SE12.bin". I am not sure what other information to provide in order to help you to help me.
If any ideas please let me know.
Thanks again.
Take the Picture of the device Front and Lable attached to this thread.
or
check the Google images which you can identified as same switch ?
or
Conenct the console, Switch of the device and switch and post the boot logs (i know it will not boot, but you get some information in the startup process)
BB
Sorry for the late reply.
when the switch boot i see the below:
switch:n compl
switch:
switch:
switch:ding "f
switch:0e-univ
switch:z.150-2
switch:g flash
switch:]: mifs
switch:k 1 sec
switch:
switch:
switch:
switch:
switch:
switch:
switch: for Bo
switch:
switch:rrupt w
switch:econds
switch:boot pr
switch: Loader
switch:not req
switch:age 2)f
switch:
switch:
switch:
switch:
switch:
switch:
switch:oot pro
switch:ed...
switch:
switch:PS: Fl
switch:switch:
switch:ginotal
switch:
switch:
switch: cmd: B
switch:
switch:
switc
switch:
switch:POST: T
switch:
switch:Interru
switch: 5 seco
switch:ort boo
switch:.d, Sta
switch:
switch:
switch:
switch:
switch:
switch:
mi
switch:i
switch:witch:
switch:
POS
switch:
switch:-- Pres
switch:of avai
switch:mandsit
switch:n compl
switch:
switch:
switch:
switch: reboot
POST
Unknown cmd: rebootry T
switch: boot arp
Loading "flash:c3560e-universalk9-mz.150-2.SE8.bin"...flash:c3560e-universalk9-mtatus Passedrphaned
boot -- Load and boot an
Error loading "flash:c3560e-universalk9-mz.150-2.SE8.bin"n Tota
Interrupt within 5 seconds to abort boot process. cat -- Concatenate (type) file(s)OST: CPU M
Boot process failed...ests
switch:
switch:
switch:
switch:
switch:y -- C
switch:
switch:ping --
switch:P ECHO_
switch:ack
switch:
switch:
switch:
switch:
switch:
switch:
switch:- Renam
switch:
switch:
switch:iting f
switch:ownload
switch:
switch:
switch: Reset
switch:m_end_u
switch:
switch:
switch:
switch:This pr
switch:
switch: r
switch:elete e
switch:s) subj
switch:ited In
switch:r Con
switch:
switch:
switch:
switch:
switch:MORE --
switch:
switch:
switch:t -- Se
switch:lay env
switch:variabl
switch:governi
switch:, expor
switch:er and
switch:
switch:
switch:
switch:
switch:
switch:
switch:t_bs --
switch:ibutes
switch: sector
switch:emer
switch:
switch:
switch:
switc
use. D
switch:f Cisco
switch:aphic p
switch:oes not
switch:
switch:
switch:
switch: set_pa
switch:t syste
switch:
switch:
switch:
switch:
switch:Pause (
switch:r a spe
switch:mber of
switch:rtASIC
switch:t
switch:
switch:
switch:
switch: boot
type -- Concatenate (type) file(s)ible fort Loopback Test
POST: PortASIC Ma
Error loading "flash:c3560e-universalk9-mz.150-2.SE8.bin"riable
Boot process failed... null[8]: (read-
switch: help/export/cryp
? -- Present list of available commands
arp -- Show arp table or arp-resolve an address
If you requi
boot -- Load and boot resete plea
cisc
Using drive
flash_init -- Initialize flash filesystem(s)2144K bytes of mrs a
format -- Format a filesystem
Base ethernet MAC
fsck -- Check filesystem consistencyor
help -- Present list of available commandsstem is available.l country laws. By using thi
memory -- Present memory heap utilization information
The password-recovery mechani
mgmt_clr -- clear management port statistics
http://www.c
Base
mgmt_init -- initialize management port : 4194304
mgmt_show -- show management port statis
set_bs -- Set attributes on a boot sector filesystemes used : 9216
set_param -- Set system parameters in flashe :
Hardware Board R
sleep -- Pause (sleep) for a specified number of secondss available : 57662464 : FD
Loading "flash
Initializing Flash....150-2.SE8.bin"...fla
...The flash is already initialized.
switch: write erase
* 1 54
Unknown cmd: write 15.0(2)SE8
switch: erase
Unknown cmd: eraset within 5 seconds
switch: boot process.LEV
Loading "flash:c3560e-universalk9-mz.150-2.SE8.bin"...flash:c3560e-universalk9-mTop Assembly Part Number
z.150-2.SE8.bin: no such file or directoryhe system is unable to boot automatically.
Hardware Board Revi
Interrupt within 5 seconds to abort boot process. be set to a bootableOWN: Line
switch: flash_init
nged st
Initializing Flash... ------
...The flash is already initialized.MAC Address: 24:e9:b3:ae:6a:80ine pr
switch: format_flashstEthernge
Unknown cmd: format_flash
switch: help
Xmod
boot -- Load and boot an executable image
Initializing Flash...: Extended SysId enab
cat -- Concatenate (type) file(s)2]: 12 files, 1 directories
copy -- Copy a fileifs fsck took 3 seconds.RJ4
delete -- Delete file(s)
*Mar
dir -- List files in directoriesnstall
mgmt_show -- show management port statistics1:44.454: %DC-4-FIL
mkdir -- Create dir(s)
mifs[6]: Total
more -- Concatenate (display) file(s)UPDO
ping -- Send ICMP ECHO_REQUEST packets to a network host 9216ern
e_dir/dc_defau
rename -- Rename a files[6]: Bytes available : 57
...done Initializing Flash.rted.
set_bs -- Set attributes on a boot sector filesystem:c3560e-universalk9-mz.150-2.SE8.bin"...flash:c3560e-unive
Enable secret warning.
unset -- Unset one or more environment variables
switch: load_helper
version -- Display boot loader versionnown cmd: load_helperet using the following
switch: format flash
Unknown filesystem "flash":mode-O-5-UPDOWN: L
switch: format
bs[0]: (read-only) changed state to d
flash[6]: (read-write)
3 -rwx 5 <date
xmodem[7]: (read-only)to enter the initial configuration d
null[8]: (read-write)
tftp[9]: (read-only)
4 -rw
switch: format flash: multiple-fs
Are you sure you want to format "flash:" (all data will be lost) (y/n)?yh>enableown
Switch#
switch: BB0BB0hanged state
mifs[6]: 0 files, 1 directoriesknown cmd: BB0BB0NGHOST_STARTST
mifs[6]: Total bytes : 57671680
switch: BB0BB00.
mifs[6]: Bytes used : 1024GR-
mifs[6]: Bytes available : 57670656k9-mz.122-5
Unknown cmd:
switch:ch#w
usage: copy [-b <buffer_size>] <src_file> <dst_file>
switch: flash:
Unknown cmd: flash:
switch: dir
List of filesystems currently registered:
bs[0]: (read-only)
switch: dir flash:
57670656 bytes available (1024 bytes used)
switch: BB0BB0
Using driver version 3 for media type 2
Base ethernet MAC Address: 24:e9:b3:ae:6a:80
Xmodem file system is available.
The password-recovery mechanism is ena
mifs[2]: 12 files, 1 directories
mifs[2]: Total bytes : 2097152
mifs[2]: Bytes used : 755200
mifs[2]: Bytes available : 1341952
mifs[2]: mifs fsck took 1 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes : 4194304
mifs[3]: Bytes used : 1024
mifs[3]: Bytes available : 4193280
mifs[3]: mifs fsck took 3 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes : 524288
mifs[4]: Bytes used : 9216
mifs[4]: Bytes available :
mifs[4]: mifs fsck took 0 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes : 524288
mifs[5]: Bytes used : 9216
mifs[5]: Bytes available : 515072
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: mifs fsck took 32 seconds.
done.
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
image.
switch:
Thanks.
Leo Laohoo
This is a 3560E, right? Look at the back. Can you see a USB port?
The command to boot an IOS from a USB port is "boot usbflash0:IOS_filename.bin".
NOTE: They erased the IOS but they left the config behind? Amateurs!
Hi Leo, thanks for replying. The label at the back states the below:
TNY-WS3750X-3560X (A)
Yes I can see usb port, in fact I tried copying the IOS through it and failed. I tried using both IOS (3750 & 3560 ) see below:
switch: boot usbflash:c3750-ipbasek9-mz.150-2.SE11.bin
Loading "usbflash:c3750-ipbasek9-mz.150-2.SE11.bin"...usbflash:c3750-ipbasek9-mz
.150-2.SE11.bin: no such device
Error loading "usbflash:c3750-ipbasek9-mz.150-2.SE11.bin"
switch: boot usbflash0:c3560e-ipbasek9-mz.122-55.SE12.bin
Loading "usbflash0:c3560e-ipbasek9-mz.122-55.SE12.bin"...usbflash0:c3560e-ipbase
k9-mz.122-55.SE12.bin: no such device
Error loading "usbflash0:c3560e-ipbasek9-mz.122-55.SE12.bin"
switch:
i properly checked the file was on the USB drive, formated it and tried again making sure it was the only file(with each file 3750 & 3560 separately) to avoid conflict with other files, but no luck.
BB
Thanks a lot. i will try
Thanks a lot. This helped me to fix the issue.
I booted from the usb and worked perfectly.
Thanks again.
