Cisco 2960 RESET
darren849
                   I have a cisco 2960 that I seemed to have lost the password. Its just a test switch. I would like to know how to reset it to factory default. I have managed to get to a switch: prompt by holding in the small mode button on the front of the switch and pluging in the power but lost from here.
Ivan Shirshin
Hi Darren,
Run the follwing comands:
     flash_init
     load_helper
     dir flash:
     rename flash:config.text flash:config.old
     boot
Please see the following guide for thecomplete procedure:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
