OSPF per Interface configuration
Krasnoperov
Level 4
Level 4
I have this situation
sw1(3560)<---ospf-->sw2(3560)---->users( vlan 1)
sw1
interface g0/1
no switchport
ip address 10.0.0.2 255.255.255.0
router ospf 1
passive interface default
no passive interface g0/1
network 10.0.0.2 0.0.0.0.0 area 13
sw2
interface vlan 1
ip address 10.0.0.1 255.255.255.0
router ospf 1
no passive interface vlan 1
network 10.0.0.1 0.0.0.0.0 area 13
My question is, when I configuring this
Will I be sure that some of users in vlan 1(on sw2) do not sniff my routing table, or fo not inject some routes in my routing table? thanks
cadet alain
if you want to prevent route injection then use md5 authentication and  as OSPF is not advertising the routing table, you can be safe about sniffing because all they can see is hellos and LSAs but you can use unicast peering  to mitigate this.
Regards.
Alain
