Cisco 2960-S Switch
Adrian Castro
Hi Guys,
The switch port of the 2960-S switch turns amber after accidentally connected the cable to the uplink port, I already perform shut and no shut command and still the port was still amber, what do I need to do? Please help. Thanks!
BTW here's the config FYR:
interface GigabitEthernet1/0/33
 switchport access vlan 38
 switchport mode access
 switchport voice vlan 16
 mls qos trust cos
 spanning-tree portfast
 spanning-tree bpduguard enable
 spanning-tree guard root
Interface status:
GigabitEthernet1/0/33 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 544a.0038.d321 (bia 544a.0038.d321)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
     reliability 248/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 5d03h, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 34
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 155098 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     605 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     467 packets output, 50189 bytes, 0 underruns
     0 output errors, 18 collisions, 3 interface resets
Leo Laohoo
Bad cable.
Do this:
1.  Command:  test cable tdr interface GigabitEthernet1/0/33;
2.  Wait for about 5 to 7 seconds;
3.  Command:  sh cable tdr interface GigabitEthernet1/0/33; and
4.  Post the output to #3.
Thanks, I'll try to do this.
Btw. There is no cable on the switch port when I perform the interface status and even without  cable it was still amber, I didn't know why reliability becomes like that.
Did you tried rebooting the switch?
Inayath
This means you've got a line fault.
And this confirms you've got a line fault.
This means the last traffic sent by the switch was 5 days ago.
This tells me of a short burst of traffic before the interface went down.
Don't worry about the amber LED.  Connect a working client with a known working cable and the LED should turn to green.
