Join Customer Connection to register!
36753
senthilgm2000
Beginner
Cisco 2960 switch ports flapping - Urgent
*Apr  3 05:56:08.795: %LINK-3-UPDOWN: Interface FastEthernet0/27, changed state
to down
*Apr  3 05:56:11.488: %LINK-3-UPDOWN: Interface FastEthernet0/27, changed state
to up
*Apr  3 05:56:12.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/27, changed state to up
*Apr  3 05:56:31.377: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/35, changed state to down
*Apr  3 05:56:32.384: %LINK-3-UPDOWN: Interface FastEthernet0/35, changed state
to down
*Apr  3 05:56:35.303: %LINK-3-UPDOWN: Interface FastEthernet0/35, changed state
to up
*Apr  3 05:56:36.310: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/35, changed state to up
*Apr  3 05:57:20.954: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/18, changed state to down
*Apr  3 05:57:21.952: %LINK-3-UPDOWN: Interface FastEthernet0/18, changed state
to down
*Apr  3 05:57:25.031: %LINK-3-UPDOWN: Interface FastEthernet0/18, changed state
to up
*Apr  3 05:57:26.037: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/18, changed state to up
*Apr  3 05:59:23.352: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/7, changed state to down
*Apr  3 05:59:24.350: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state t
o down
*Apr  3 05:59:31.909: %LINK-3-UPDOWN: Interface FastEthernet0/7, changed state t
o up
*Apr  3 05:59:35.230: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/7, changed state to up
*Apr  3 06:03:39.037: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/46, changed state to down
*Apr  3 06:03:40.035: %LINK-3-UPDOWN: Interface FastEthernet0/46, changed state
to down
*Apr  3 06:03:42.988: %LINK-3-UPDOWN: Interface FastEthernet0/46, changed state
to up
*Apr  3 06:03:43.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/46, changed state to up
to down
to up
to down
to up
to down
to up
o down
o up
to down
to up
1 ACCEPTED SOLUTION
Dejan Puhar
can you put show interface of one of the flapping ports?
cheers
Dejan
15 REPLIES 15
Dejan Puhar
cheers
Dejan
FastEthernet0/46 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 64a0.e79a.4e2e (bia 64a0.e79a.4e2e)
  Description: GABORONE-LAN
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute output rate 2000 bits/sec, 5 packets/sec
     2730924 packets input, 1241363631 bytes, 0 no buffer
     Received 378394 broadcasts (23743 multicasts)
     0 watchdog, 23743 multicast, 0 pause input
     15327101 packets output, 2495115743 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
This looks clean, except
  Last input never,
So it seems that he is not receiving anything on this port, you can monitor it for few min to make sure there are no packets.
Do you have some ports on this one that are fine? If yes can you try to move connection from the flapping one to that one and see if the fault is following the interface or cable.
Also what is your speed/duplex configuration here? Maybe you can try fixing it to see if that is going to help.
Dejan
HI Dejan,
Its not happening for only one port,many ports are fluctuating like the same.
now fa0/4 has gone down.
*Apr  3 06:49:31.297: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthe
et0/4, changed state to down
*Apr  3 06:49:32.295: %LINK-3-UPDOWN: Interface FastEthernet0/4, changed state
o down
BW-UTi-GABORONE-SWC01#         sh int fa0/4
FastEthernet0/4 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 64a0.e79a.4e04 (bia 64a0.e79a.4e04)
  Auto-duplex, Auto-speed, media type is 10/100BaseTX
  Last input never, output 00:43:36, output hang never
     7235487 packets input, 1593375789 bytes, 0 no buffer
     Received 53729 broadcasts (888 multicasts)
     0 watchdog, 888 multicast, 0 pause input
     18948686 packets output, 7423061327 bytes, 0 underruns
o down
*Apr  3 07:45:17.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/23, changed state to down
*Apr  3 07:45:19.996: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0/23, changed state to up
Did you find a resolution to this problem?
Hi Senthil,
I can see that you have many ports flapping, but do you have some that are working just fine? Is there anything in common for the flapping ports? Type of devices connected? Can you try to move one of the flapping devices to another switch to see if it will continue to flap, this is the fastest way to check who is going crazy.
If there is absolutelly nothing in common for the flaping ports/devices then it has to be switch misbehaving. Check cablings, patch pannel, devices...
But manipulating the cables from one device to another is the fastest way to move here.
so if you have host A connected to port A and flapping
and host B connected to port B and not flapping
just try to switch the ports for these 2 hosts and see what happens.
Let me know how it goes
Dejan
Thanks Dejan
will do and let you know
Hi Senthil,
also just in case check the CPU, memory on the switch itslef to see if there is something wrong there.
Dejan
HI Dejan,
Just to confirm with the switch is running ios 12.2 version, advice me will it be cause any way around
Put here the show ver to get all details
Hi dejan
Did this issue been closed/ resolved the problem?
i have the same problem but i am using Nexus 3k which is connected to a server.
Leo Laohoo
VIP Community Legend
Right, this is a 2960 right?  With two dual-personality ports?
For this exercise, may I request you move whatever is on ports Fa0/46 to either Gi0/1 or Gi0/2.  We're going to do some TDR testing.   If you have fibre optic in either the port you are using, can I ask if we temporarily disconnect it?  This test won't take more than 10 seconds.
Here's the preliminary configurations:
conf t
interface Gi 0/1 (or Gi 0/2)
media rj
end
1.  Command:  test cable tdr interface Gi 0/1 (or Gi 0/2);
2.  wait for 5 to 7 seconds;
3.  Command:  sh cable tdr interface Gi 0/1 (or Gi 0/2);
4.  Post the output
Remove the cable from either Gi 0/1 or Gi 0/2 and return to Fa 0/46.  Undo the temporary changes to the SFP ports using the commands:
conf t
media auto
end
We await for your result.
ebarticel
Enthusiast
Just to add something to discussion...
Did you add a switch to the topology?
Eugen
