Cisco 2960 (WS-C2960-8TC-L) with SFP (GLC-FE-100FX) duplex issues
Jim Bell
Hi There,
We have 2 Cisco 2960's (WS-C2960-8TC-L) trunked together via interface Gi0/1 on each switch using SFP's (GLC-FE-100FX). Switch Version 12.2(50)SE3
Although the link is up and operational it is only running at half-duplex (a-half a-100) and we are unable to force speed or duplex changes on interface Gi0/1.
Gi0/1 .1Q TRK to SW2  connected 1 a-half  a-100  100BaseFX-FE SFP
Should this configuration set-up run at a-full a-100 or do we need a different IOS image.
Thanks in advance
Jim.
Jon Marshall
argyll-bute wrote:
Hi There,
Thanks in advance
Jim.
Jim
Under the gigabit interfaces add this -
int gi0/1
media-type sfp
then you should be able to configure duplex/speed settings.
Jon
Jon Marshall
argyll-bute wrote:
Hi There,
Thanks in advance
Jim.
Jim
int gi0/1
media-type sfp
Jon
Jon,
That has worked now allows me to alter the duplex setting (speed cannot be altered due to to fixed rate of SFP).
Thanks for your help
Jim.
