Cisco 2960G disable srr-queue on switchport
arnetcis01
I have a Cisco 2960G switch and one of the ports was configured with srr-queue bandwidth limit 90 - I need to remove this bandwidth limiting from this interface.
Would this be the correct sequence of commands?
swh02#conf t
swh02(config)#int gig0/12
swh02(config-if)#no srr-queue bandwidth limit 90
swh02(config-if)#exit
swh02(config)#exit
swh02#wr mem
This is the swichport interface in question the configuration below:
interface GigabitEthernet0/12
description N12: NewUser1
switchport access vlan 47
switchport mode access
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
load-interval 30
spanning-tree portfast
spanning-tree bpduguard enable
end
Vivek Ganapathi
Level 4
Level 4
You can accomplish this with just "no srr-queue bandwidth limit" command under your interface.
Thank you Vivek.
