Router connection
aslam mohammad
        How to connect multiple routers in same LAN with configuration
smehrnia
Level 7
Level 7
from a conceptual prespective, you have to connect routers to a Layer 2 device (i.e. a Switch) and configure the interfaces of the routers that you want to serve a particular LAN, an IP address with a same Network ID.
ask for more.
plz Rate if it helped.
Soroush.
Hope it Helps!
Soroush.
