Cisco 2960S multicast routing
egiovannetti
Hi all,
Having 2 cat 2960S in stack, do they support vlan routing and multicast routing?
Thank you very much.
Emanuele
2 Accepted Solutions
Latchum Naidu
Hi Emanuele,
2960 is a pure layer 2 switch. It doesnot support layer-3 capabiltities like basic routing and IVR. Its not supported in standard and even in enhanced IOS.
Please rate all the helpfull posts.
Naidu.
Naidu,
I respectfully disagree. Since IOS version 12.2(55)SE, the support for static unicast IPv4 routing was added to 2960 and 2960-S Catalysts. Hence, 2960 and 2960-S can provide basic inter-VLAN routing services. They do not support routing protocols, though, and also they do not support multicast routing.
Please consult the following documentation for more information:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/15.0_1_se/configuration/guide/swipstatrout.html
Best regards,
Peter
Latchum Naidu
Hi Emanuele,
Naidu.
Naidu,
Best regards,
Peter
egiovannetti
Ok
Thank you so
much
egiovannetti
Sorry i mistaken to mark the answer
