09-17-2015 09:39 AM - edited 03-08-2019 01:50 AM
Hello, I have a Cisco 2960S switch, presently I have a multimode fiber uplink plugged in to it. base 1000sx , GBIC ,SPF port. can I add another uplink using Single Mode Fiber , and will they run at the same time on this switch?
09-17-2015 11:36 AM
Hi yes the fibre mode is irrelevant to the port itself you have combinations of either once you have enough ports
09-17-2015 02:52 PM
Feedback Forum is dedicated to other topic. Please use appropriate forum for your questions in the future. This discussion has been moved to Getting Started with LANs
09-23-2015 08:35 AM
As suggested, Fiber mode SM or MM is irrevalent with ports.They can run simultaneously if you have supported SFP to run.
--GI
