Cisco 2960X QinQ Supported?
zackstanek
Would anyone happen to know if QinQ is supported for Cisco 2960X Switches running the latest version of IOS? I have performed a quick search through the Configuration Guide for the latest IOS release however I do not see any information regarding QinQ being supported for the 2960X.
I found a Support thread that did indicate it is not supported for the 2960X model however I did not see any Cisco documentation that indicated that was the case.
(Link to Support thread - https://supportforums.cisco.com/discussion/12927511/qinq-2960-xxr)
(Link to the latest 2960X Configuration Guides - http://www.cisco.com/c/en/us/support/switches/catalyst-2960-x-series-switches/products-installation-and-configuration-guides-list.html)
Thank you,
Zack
Mark Malone
I don't see it either under the data sheet for 2960x models as a supported feature and that was last updated this month
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/data_sheet_c78-728232.html
Julio E. Moisa
Check this link and search by Q-in-Q VLAN Tunneling
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
I think it is not supported on 2960 serial models.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
This is the same link the OP posted :-)
Reza
Julio E. Moisa
I have verified on one of my Cisco switches 2960X and it is not supported:
Switch details:
WS-C2960X-24TD-L
IOS 15.0
ABCDE(config-if)#switchport mode ?
access Set trunking mode to ACCESS unconditionally
dynamic Set trunking mode to dynamically negotiate access or trunk mode
trunk Set trunking mode to TRUNK unconditionally
Hope it is useful
