09-02-2018 10:09 PM - edited 03-08-2019 04:03 PM
Hi friends
We are facing issue with Cisco 2960X series switch booting issue.
Switch is power ON, but not clearing the boot cycle. The attached screen shot for your better understanding.
pls help
Solved! Go to Solution.
09-02-2018 11:53 PM - edited 09-03-2018 12:00 AM
Raise a TAC Case and get them to confirm if you're hitting CSCvf24186 or not.
You could try this work-around:
1. Force the appliance to boot into ROMmon;
2. Download a different IOS version, say 15.0(2)SE12. Download the BIN file;
3. Copy the BIN file into a a USB flash drive;
4. Force the switch to boot the BIN file from the USB flash drive using the command "boot usbflash0:filename.bin".
5. Once the appliance boots up 15.0(2)SE12, reboot the switch and see if the intended IOS gets loaded or not.
09-03-2018 12:04 AM
i will try leo
