Cisco 3508G XL
miguel.tome
I have a problem with a catalyst 3508G XL ...
The problem is as follows:
When I power on the system LED keeps blinking and does nothing.
I've tried connecting the cable to the console port, but can not communicate.
Someone can help me?
mvknl
Did you check the terminal settings you use? They should be as follows:
Bits per sec    :  9600
Data bits       :     8
Parity          :  none
Stop bits       :     1
Flow control    :  none
If they are correct you should at least see some output while booting.
