Cisco 3550-F L1 Matrix Switch Capability
Reha Diri
I wonder to know Cisco 3550-F Layer-1 matrix switch routing capability. Does this switch supports VLANs and can do static routing ? Its not so clear in its datasheet.
Best Regards,
Reha Diri
I guess this switch is only for network tapping , nothing else.
for me the SW support VLAN and you can config static route in this SW series
Thanks A Lot
MHM
I have read the following document and confused . It says there Cisco 3550-F Modular L1 Matrix Switch and Programmable Multiplexer Switch Datasheet. It seems that there are two different switches with different functionalities. Am i wrong ?
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-3550-series/datasheet-c78-743963.html?ccid=cc001479&oid=dstdnc022107
Thanks a lot
Best Regards
this is NSK so you need feature
feature inter-vlan <<- for VLAN
for static you dont need any feature.
but I will take look to your datasheet (which I think talking about the fix via module add port to NSK ).
Thanks A Lot
MHM
