Cisco 3560 as L2 switch with no intervlan routing.
Gdlgiii
I have a basic question that I hope I can get some assistance for. I have two Cisco 3650 switches that I want to create two vlans on and configure two separate VLANS with no iprouting between the two. The first one will be on second floor with EdgeRouter that will handle DHCP and routing. The second switch will be downstairs connected to a single cable drop. I would like to know how I can create two VLANs on each switch. i would like to use the two Gb ports on each as uplink ports to connect the two switches together and the second Gb port on the first switch upstairs to be the uplink to the Ubiquity router that will then connect to the ISP cable modem.
I want to have the private vlan to be the default vlan for untagged ports and set some of the ports to use both VLANs or would it be better to specify each port with the specific vlan? I drew up a quick diagram of what I think this should look like.
2 Accepted Solutions
Deepak Kumar
Yes, Mr. @paul driver is right. This is the best way to the configuration.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
@Gdlgiii wrote:
Thank you very much for your help in this! Seeing that really helps me understand more on how to configure these but devices. SVI is where the IP for vlan 10 is defined? What about vlan 50? Would that need an IP address as well? My plan is to put smart devices and smart bulbs and Google home on the van 50 by hanging a Netgear r8000 router in IP vlan mode and configure it as a WiFi AP that will only have access to the Internet and not able to see other devices in vlan 10. Would devices that so not understand vlans be connected to ports that are untagged with a default network on vlan10?
You mentioned the rtr will be perfroming the routing/Dhcp as such that will be where the addressing for vlan 10 and vlan 50 will reside.
The SVI 10 I used because you shown it in your drawing and to avoid more confusion for yourself However this SVI can be any MGT subnet other than vlan10/50 as long it also resides on the rtr -  its just for remote administration of the two switches.
As I said the rrtr  most probably will have a physical interface with subinterfaces and the address ranges for vlan 10/50 applied - somethig like this:
RTR
int x/x
description link to switch 1
int x/x.10
description Vlan 10
ip address 10.10.10.254 255.255.255.0
int x/x.50
description Vlan 50
ip address 50.50.50.254 255.255.255.0
As long you have a trunk from switch 1 to the rtr and have the L2 vlans defined on each switch then it would just be matter of the assigning each port the correct vlan.
Lastly you mentioned you didn't want vlan 10 and vlan 50 traffic communicate with each other, this can also be accomplished on the rtr with access-lists
res
Paul
Kind Regards
Paul
6 Replies 6
Hello
If the router is to handle the routing and dhcp and as it will alsol have a interface for each vlan  then all you need to do it create svi 10 on each switch and have their default gateway point to the rtr.
sw1
int gig0/0
description RTR interface
switchport trunk dont1q encapsulation
switchport mode trunk
int gig0/1
description link to Switch 2
int vlan 10
ip address 10.10.10.1 255.255.255.0
ip helper address ( dhcp server of rtr)
exit
no ip routing
ip default-gateway 10.10.10.254
vlan 10, 50
exit
int x/x
switchport mode host
switchport access vlan 10
int x/x
switchport access vlan 50
sw2
int gig0/1
description link to Switch 1
int vlan 10
ip address 10.10.10.2 255.255.255.0
exit
no ip routing
vlan 10, 50
exit
int x/x
int x/x
res
Paul
Kind Regards
Paul
Hello
RTR
int x/x
int x/x.10
description Vlan 10
int x/x.50
description Vlan 50
res
Paul
Kind Regards
Paul
Correct, the Ubiquity edgerouter will manage the 2 vlans and dhcp scope for each. Thank you for the very useful information!
So, made progress. I have setup an Ubiquiti USG with 3 networks. Lan 1 (untagged) is 192.168.1.0/24. vlan 10 is 172.16.0.0/24, and vlan 50 is 192.168.0.0/24. I am trying to put a raspberry pi 3 with a static on the "lan" network so it is on same network as the router. Coming out of interface lan port 1 from the router is connected to port fa0/2 on the Cisco switch. I have set port fa0/1 as unconfigured and plugged the raspberry pi 3 in there but it is unable to connect to the network. If I set the pi to DHCP on port fa0/3 I get an IP from vlan 10 and can get a route to the router IP. The goal is to use the LAN network as a management network and want to set a management IP for the switch itself on to the management LAN.
Why can't I get connectivity to the router if setting the static IP to the LAN network. Attached is the switch config
Deepak Kumar
Deepak Kumar
Deepak Kumar,
