cisco 3560 ip-mac filtering problem
cristian.barean
Community Member
Hello!
My name is Cristian Valentin Barean.
For about a month I have a cisco 3560 switch mounted as main gateway-router for about 1000 users. Everything works fine except static ip-mac filtering on ports.
My gateway vlan is 10, and have 16 ports on that vlan.
for ip-mac filtering I did the folowing on the switch:
ip dhcp snooping vlan 10
ip dhcp snooping
ip source binding 000E.E88D.9F42 vlan 10 89.114.37.167 interface Gi0/22
ip source binding 0030.1B16.8C53 vlan 10 89.114.36.146 interface Gi0/10
ip source binding 0040.F4B4.CF53 vlan 10 89.114.36.134 interface Gi0/24
ip source binding 00C0.DF11.E8E0 vlan 10 89.114.32.90 interface Gi0/15
ip source binding 000C.6EC8.5238 vlan 10 89.114.36.93 interface Gi0/24
interface Gi0/24
switchport access vlan 10
switchport mode access
switchport port-security
flowcontrol receive desired
ip verify source port-security
and so on for all vlan 10 interfaces
on the firt few seconds even minutes on the command
sh ip verify source interface Gi0/24
I get correct filtering setings:
Interface Filter-type Filter-mode IP-address Mac-address Vlan
Gi0/24 ip-mac active 89.114.33.142 0040.3445.2334 10
Gi0/24 ip-mac active 89.114.33.102 0040.3675.2894 10
and the filtering works.
After a few minutes the traffic on switch stops and on the same command I get:
Gi0/24 ip-mac inactive-no-snooping-vlan
Without any transfer on that port the ip-mac filtering stayes active.
I have tested and the latest software IOS version 12.2(35)SE1, and got the same problem.
Can someone tell me if, am i doing something wrong or is it a bug?
Thank You !
cristian.barean
Community Member
Resolved
Added:
switchport port-security maximum xxx
switchport port-security violation restrict
And works
