10-22-2007 12:00 AM - edited 03-05-2019 07:13 PM
I have a cisco 3560 which hangs. I am able to ping the switch and connect via snmp to see some of the information but cannot telnet to it. Users are losing connections. I am running the following version of software - Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1). any assistance would be appreciated.
10-22-2007 12:07 AM
Please post the output from the boot sequence including the self test (POST).
Any errors there? If so, you may have a hardware problem.
Leo
10-22-2007 03:09 AM
Hi Leo
Don't have the boot sequence output as the switch is running.
Details from POST
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC PortASIC interface Loopback Tests : Begin
POST: CPU MIC PortASIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Also some errors from the logging
Log Buffer (4096 bytes):
x0055F278 SRR3 = 0x00021000
00:03:34: %PLATFORM-1-CRASHED: ESR = 0x00000000 DEAR = 0x00000000 TSR = 0x8C000000 DBSR = 0x10000000
00:03:34: %PLATFORM-1-CRASHED: CPU Register Context:
00:03:34: %PLATFORM-1-CRASHED: Vector = 0x00002000 PC = 0x008D33F8 MSR = 0x00029210 CR = 0x35000035
00:03:34: %PLATFORM-1-CRASHED: LR = 0x008D3320 CTR = 0x001DD03C XER = 0xC0000063
00:03:34: %PLATFORM-1-CRASHED: R0 = 0x00000000 R1 = 0x03447C40 R2 = 0x00000000 R3 = 0x00000000
00:03:34: %PLATFORM-1-CRASHED: R4 = 0xFFFFFFFE R5 = 0x00000000 R6 = 0x03447C18 R7 = 0x00000000
00:03:34: %PLATFORM-1-CRASHED: R8 = 0x00029210 R9 = 0x015D0000 R10 = 0x018E9588 R11 = 0x00000000
00:03:34: %PLATFORM-1-CRASHED: R12 = 0xA0000000 R13 = 0x00110000 R14 = 0x0000000A R15 = 0x00000002
00:03:34: %PLATFORM-1-CRASHED: R16 = 0x00000001 R17 = 0x015D0000 R18 = 0x0335B474 R19 = 0x00000002
00:03:34: %PLATFORM-1-CRASHED: R20 = 0x01CEA9C8 R21 = 0x05F1145C R22 = 0x000BB095 R23 = 0x01EA3854
00:03:34: %PLATFORM-1-CRASHED: R24 = 0x00000000 R25 = 0x00DFBD04 R26 = 0x000BB095 R27 = 0x01EA3054
00:03:34: %PLATFORM-1-CRASHED: R28 = 0x0149A754 R29 = 0x014A6A9C R30 = 0x00000000 R31 = 0x01EA3024
00:03:34: %PLATFORM-1-CRASHED: Stack trace:
00:03:34: %PLATFORM-1-CRASHED: PC = 0x008D33F8, SP = 0x03447C40
00:03:34: %PLATFORM-1-CRASHED: Frame 00: SP = 0x03447C50 PC = 0x008D32F8
00:03:34: %PLATFORM-1-CRASHED: Frame 01: SP = 0x03447C78 PC = 0x00E3D834
00:03:34: %PLATFORM-1-CRASHED: Frame 02: SP = 0x03447CA8 PC = 0x00E35EE4
00:03:34: %PLATFORM-1-CRASHED: Frame 03: SP = 0x03447CE8 PC = 0x00DFBD08
00:03:34: %PLATFORM-1-CRASHED: Frame 04: SP = 0x03447D30 PC = 0x00D81080
00:03:34: %PLATFORM-1-CRASHED: Frame 05: SP = 0x03447D90 PC = 0x00D5F9BC
00:03:34: %PLATFORM-1-CRASHED: Frame 06: SP = 0x03447DF8 PC = 0x00D52CC4
00:03:34: %PLATFORM-1-CRASHED: Frame 07: SP = 0x03447E40 PC = 0x00D78528
00:03:34: %PLATFORM-1-CRASHED: Frame 08: SP = 0x03447E48 PC = 0x008D5124
00:03:34: %PLATFORM-1-CRASHED: Frame 09: SP = 0x00000000 PC = 0x008CB6EC
The system seems to have rebooted itself and is working OK at the moment. The hanging happened on another switch which we then replaced with the current one. This one has worked fine for several months but now has started hanging.
Ron
10-22-2007 03:22 AM
If two devices are showing the same problem this is likely a configuration issue.
Any policing active on this switch?
Perhaps other (unusual) configuration settings that may affect performance?
Leo
10-22-2007 03:55 AM
Copy "show version" and stack trace output in the cisco output interpreter.
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
You see than Possible bug matches.
