Cisco 3560 rebooting
recently a Cisco 3560E switch went down due to a power surge. the switch is getting power but i am only seeing the below message continously. it is keep on rebooting. i try to reset to factory settings/ safe boot nothing worked. is there any way i can bring the switch up or it is hardware failure
Using driver version 1 for media type 2
Base ethernet MAC Address: 00:23:33:af:1b:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
5 Replies 5
Reza Sharifi
Try this link and see if you can load a new IOS to your switch.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
I already tried it didn’t work
Leo Laohoo
3560E, right?  Power down.  Remove power cable.  Remove the power supply and insert firmly.  Try again.
If it doesn't help, RMA the appliance.
Didn’t work
Didn’t work
Contact Cisco TAC and RMA the appliance.  The power spike may have burnt a few components.
