cisco 3560 switch| mls qos trust dscp question
sarahr202
Level 5
Level 5
Hi everybody
Hi everybody .
Please consider the following example:
3560 sw f1/1--------trunk---SW2
3560 sw
f1/1
mls qos trust dscp
3560 is using default cos-dscp map, assume a 3560 receives a frame carrying IP packet on f1/1 with COS 4, what will 3560 switch do?
1) will it use its default cos --dscp map  ( cos 4--.dscp 32) and rewrite 32 in dscp field  of the packet in the frame and provide PHB for dscp 32 ?
Much appreciated!!
Have  a great weekend.
mlund
Level 7
Level 7
No it will not trust the cos value, because You have configured to trust dcsp. So, the switch will trust the dcsp value in the incoming frame.
/Mikael
mlund
Level 7
Level 7
/Mikael
thanks Mikael
