04-03-2014 11:31 AM - edited 03-07-2019 06:58 PM
I can't seem to get my Cisco 3560 switch to give do DHCP for my SAP 1602 guest network... No wireless controller.
I will post relevent sections of the configs.
SAP1602:
ssid avmaguest
antenna gain 0
peakdetect
dfs band 3 block
stbc
beamform ofdm
mbssid
channel dfs
station-role root
interface Dot11Radio1.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 spanning-disabled
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.20
no ip route-cache
bridge-group 20
interface BVI1
mtu 1514
ip address 192.168.1.20 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.253
Cisco 3560 Switch:
ip routing
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.20.1 192.168.20.20
ip dhcp pool WIRELESS
import all
network 192.168.20.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.20.1
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
description 4-11-2 Studio
switchport trunk allowed vlan 1,20
switchport mode trunk
spanning-tree portfast
interface Vlan1
ip address 192.168.1.10 255.255.255.0
ip helper-address 192.168.1.251
interface Vlan20
description Wireless Guest
ip address 192.168.20.1 255.255.255.0
ip access-group 100 in
ip access-group 100 out
ip route 0.0.0.0 0.0.0.0 192.168.1.253
04-03-2014 11:50 AM
I'm assuming you mean for vlan 20? If so, you have the acls on the svi for vlan20. If you remove those, does it work? If so, can you post your acl?
