CISCO 3560C SWITCHS VRF
zamoranoco
Hi everybody,
I have several 3560C switches  and I need to configure VRF on them.
Now the switches are on IOS version 12 where it seems there are lite VRF, but I need full VRF capacity.
 Can anybody help me to find out if I can use full VRF and how? Newer IOS version? advanced IP services?
Thanks.
acampbell
May be have a look at the 3560C Q & A link:-
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-c-series-switches/qa_c67-650819.html
You cannot run IP services on a 3560C just IP Base
Software feature license
2960 and 3560 Series compact switches use a nonlicensing model. That is, they either use a LAN Base or LAN Lite in case of a 2960 Series and IP Base for the 3560 Series Switch
2960-C and 3560-C Series Switches use a licensing model for software images. Both operate on a universal software image. The 2960-C model supports LAN Base and LAN Lite. 3560-C Series supports IP Base on all models. No IP Services support
Alex
Regards, Alex. Please rate useful posts.
