Cisco 3560CX
BenBautista8672
 I am trying to search where it say the Cisco 3560CX switch does not support control plane similar to higher end catalyst switches or routers.
marce1000
  - Ref : https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/mg-catalyst-2960cx-3560cx-to-9200cx-series.html
   >...Control Plane Policing (CoPP) - CoPP is enabled on the Cisco Catalyst 9200CX Series with default policing rates for different classes of traffic. These policing rates are optimized for a typical campus environment. The policing rates can be changed or disabled for different application environments. On the Cisco Catalyst 2960CX/33560CX Series, CoPP is not enabled by default, but the system provides a macro to create the different classes, and the user can specify the policing rate for different classes.
  M.
marce1000
  M.
Joseph W. Doherty
Helpful if you could provide a reference.
I suspect @marce1000 's reply says otherwise, i.e. CoPP is supported, just different defaults.
