Cisco 3650-48PS Switch Stacking Priority
bensservice007
I currently have 3 cisco 3650 switches stacked and configured. I want to prioritize the switches (all currently at 1 for value) in the same role they are currently in. Below is what I'm trying to accomplish but what I'm wondering will this mess with any configuration (vlans on ports, access port, trunk ports, ect) other than the priority after a reload. And to my understanding the priority value will not take place until I reload the switches correct?
Current Priority:
Switch A: Priority 1 - Active
Switch B: Priority 1 - Standby
Switch C:  Priority 1 - Member
Wanting to change Priority:
Switch A: Priority 15 - Active
Switch B: Priority 14 - Standby
Switch C:  Priority 13 - Member
Joseph W. Doherty
". . . but what I'm wondering will this mess with any configuration (vlans on ports, access port, trunk ports, ect) other than the priority after a reload."
It should not "mess" with your config.
"And to my understanding the priority value will not take place until I reload the switches correct?"
Yes and no.  I believe it will take effect at the next stack election, regardless of cause.  I.e. reloading the stack would be a "cause" of a stack election, but so then so would be failure of the currently active switch.
Joseph W. Doherty
