I have a query regarding the Cisco 3650 switch; as I understand that it is able to act as MC/MA for mobility; I was wondering if there is anyway to disable the services completely if it is not used for security hardening? I have illustrated some of the commands I would apply on the switch below:
no wsma agent notify
no wsma agent filesys
no wsma agent config
no wsma agent exec
no wsma profile listener httplistener
no wsma profile listener httpslistener
I was wondering if there is any other commands which is required to turn off MC/MA/mobility? I understand that the switch by default is MA however not too sure if there is a way to disable/turn it off completely due to security hardening concern?
Any suggestion is appreciated.
Thanks.
