04-17-2007 07:47 PM - edited 03-05-2019 03:31 PM
As I try to configure this cisco, i notice that it does not support the command modem and even the first system configuration dialog will generate error after it finish the wizard. the ios version: IOS (tm) 3700 Software (C3725-I-M), Version 12.3(6b), RELEASE SOFTWARE (fc1)
Does it required to update the ios or license to support the modem feature? the purpose is to install it as a RAS.
04-17-2007 07:53 PM
did u check whether your network module has got detected by the current ios ?
you can verify the same using show version command and find whether your module is getting displayed.
regds
04-17-2007 08:02 PM
it has been detected as undefine port type 400 during start up, but in the show version it does not list.
04-17-2007 08:25 PM
Do ensure that your modules are getting displayed in your show version command which is the only proof of your ios supporting the card and related commands..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
http://tools.cisco.com/Support/Fusion/FusionHome.do
The above tools will be useful to find out the ios required.
regds
04-17-2007 08:54 PM
the NM-8AM-V2 is a supported module for cisco 3725. It is also listed in the module finder (http://www.cisco.com/pcgi-bin/finder/msbsearch.pl).
But I don't know why it seem that the one I have does not recognize it. The version of IOS that I have should also support it.
04-17-2007 08:57 PM
Its not only the ios version which is required to be checked out for compatibility you need to check up the feature set too...
regds
04-17-2007 09:16 PM
So far I found that my image c3725-i-mz.12.3-6b.bin is IP feature set which does support RADIUS and should support the module nm-8am-v2. Do I need to check something else?
