04-03-2011 09:27 PM - edited 03-06-2019 04:25 PM
Do Cisco 3750G-12S's have temperature probes?
Haven't been able to get exact temperatures from any in our network. I have tried multiple switch stacks (stacks of 2 x 3750G-12S). All are using IOS 12.2(52)SE.
When I type show env temperature I get:
TEMPERATURE IS OK
When i type show env temperature status I get:
Temperature State: Not Supported
Temperature Value: Not Supported
Is this a hardware or IOS problem?
Solved! Go to Solution.
04-03-2011 09:52 PM
Could it be something with the 12S
You're right. The 12S. I have a number of stacks running 12.2(55)SE and I get:
04-03-2011 09:36 PM
I am eating my words.
I have a 3750G, 3750E and 3750X. When I use the command "sh env temp status" this is what I get.
Temperature Value: 32 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 60 Degree Celsius
04-03-2011 09:48 PM
Could it be something with the 12S? I was wondering if 12 slots filled with Fibre SFP's may effect a heat reading...?
04-03-2011 09:52 PM
