Cisco 3750 and IBM 6400 printer dropping
BILLY MCARTHUR
I am at a loss and not sure what else can be done to solve this issue.
I have a IBM 6400 printer that is connected to our cisco 3750 switch and the problem is that every 5 to 10 min the printer drops off the network.
Testing that I have conducted is the following:
Attached a small unmanaged switch to the port that is connected to the printer and connected the printer as well as a laptop to the unmanaged switch. The printer again loses connection to the network after 5 to 10 min.
Connected the printer and the laptop to the unmanaged switch, but this time did not connect it to the network and the printer stayed online.
I have had IBM come in and update the printer firmware, but this has not fixed the issue either.
The printer has a static IP and we are not seeing any other issues with devices except for this printer. The IBM techs are scratching their heads and pointing to the network as the problem. While from my testing I have to agree, but I cannot see what is causing the issue. The only other thing I can think of it would have anything to do with is the MAC address time or perhaps the ARP timeout. I am just having a tough time identifying the root issue and hope someone has some ideas for further testing.
The network is pretty flat and is only a /23. Being that it is all local to the LAN routing should not be a factor, but I am willing to try anything to get this issues addressed.
Kris
16 Replies 16
Leo Laohoo
Hi Billy,
Can you please specify the EXACT model of your 3750?
I want to know if your copper port is a GigabitEthernet or not.
If not, do you have a 3560/3750 with a GigabitEthernet?
The exact model is a C3750G-24TS and it is stacked x2. They are all GigabitEthernet ports. I have adjusted speed on the ports since the IBM printer NIC is on a 10/100 Nic. However this did not change the problem and the connection is still dropping between 5 and 10 minutes.
Any thoughts?
Kris
Woo-hoo!  Let's PLAY!!!
Right, we may be able to do some troubleshooting.
1.  Kindly post the output to the command "sh interface Gi"; and
2.  Kindly post the output to the command "sh controller e Gi"
Next, after the ones above, let's do some TDR test.  Just want to warn you that TDR can bring your connection down for approximately 5 to 7 seconds.  Here's how it's done:
1.  Command:  test cable tdr interface Gi;
2.  Wait for 5 to 7 seconds;
3.  Command:  sh cable tdr interface Gi; and
4.  Post the output to the #3 command.
I await to see the results.
Thanks again the reply Leolaohoo..
The interface output is the following
#sh interfaces gigabitEthernet 1/0/13
GigabitEthernet1/0/13 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 000f.23d8.5d0d (bia 000f.23d8.5d0d)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Half-duplex, 10Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 12000 bits/sec, 15 packets/sec
     175705 packets input, 33557775 bytes, 0 no buffer
     Received 44169 broadcasts (628 multicasts)
     0 watchdog, 628 multicast, 0 pause input
     21894690 packets output, 2151658160 bytes, 0 underruns
     0 output errors, 14 collisions, 3 interface resets
The Controller output is the following:
#sh controller ethernet-controller gigabitEthernet 1/0/13
     Transmit GigabitEthernet1/0/13           Receive
   2157729474 Bytes                         33561895 Bytes
       460755 Unicast frames                  131582 Unicast frames
      3166081 Multicast frames                   628 Multicast frames
     18332997 Broadcast frames                 43549 Broadcast frames
            0 Too old frames                10420666 Unicast bytes
           49 Deferred frames                 109004 Multicast bytes
            0 MTU exceeded frames           23032157 Broadcast bytes
            8 1 collision frames                   0 Alignment errors
            5 2 collision frames                   0 FCS errors
            1 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                  17 Collision fragments
            0 6 collision frames
            0 7 collision frames               91852 Minimum size frames
            0 8 collision frames               37828 65 to 127 byte frames
            0 9 collision frames                8132 128 to 255 byte frames
            0 10 collision frames                798 256 to 511 byte frames
            0 11 collision frames              36472 512 to 1023 byte frames
            0 12 collision frames                677 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                 17 Invalid frames, too small
     15748236 64 byte frames                       0 Valid frames, too small
      2673658 127 byte frames
      2776423 255 byte frames                      0 Too old frames
       515415 511 byte frames                      0 Valid oversize frames
       169779 1023 byte frames                     0 System FCS error frames
        76322 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
            8 Good (1 coll) frames
            6 Good (>1 coll) frames
The Cable test results:
#sh cable tdr interface gigabitEthernet 1/0/13
TDR test last run on: July 18 15:10:37
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/13  10M   Pair A     N/A                Pair B      Normal
                Pair B     N/A                Pair A      Normal
                Pair C     23   +/- 2  meters Pair D      Short
                Pair D     23   +/- 2  meters Pair C      Short
I have changed the cables. I have changed the punch. Also I have had a laptop and a unmanaged switch on this punch and port and the connection never dropped. Even thought the printer ip stops being reachable on the network, the port always appears to be connected.
Thanks again,
Kris
Also I changed the connection on the printer to be 100 half from 10 half and this was the results of the cable test. I have seriously changed the cables on both moved the punch to different locations but the results are the same no matter what I put in.
GPA-Core#test cable tdr interface gigabitEthernet 1/0/13
Link state may be affected during TDR test
TDR test started on interface Gi1/0/13
A TDR test can take a few seconds to run on an interface
Use 'show cable-diagnostics tdr' to read the TDR results.
GPA-Core#sh cable tdr interface gigabitEthernet 1/0/13
TDR test last run on: July 18 16:03:44
Gi1/0/13  100M  Pair A     N/A                Pair B      Fail
Results from 100 Full
TDR test last run on: July 18 16:27:52
I have read through a ton of the documentation about the printer connecting to the network and the best setting for it is at 10 half. Also I moved the connection to the 3750 so that I could perform testing since the switch it was on was a Cisco Small Business Switch.
Thanks again
Kris
Thanks.  The output are very, very helpful.
Firstly, excuse my ignorance because I'm no expert on the IBM printer.
I would like to know what is the "normal" NIC card of the IBM printer.  Is is 10 or 10/100BaseTx?
You see those results of the TDR?  Unless the IBM printer has GigabitEthernet, then don't worry about the bad results from Pairs C and D.
For basic (and I mean the word "basic") ethernet to work, you need at least Pair A and Pair B to come back as "Normal".  If you get a results for boths Pair A and Pair B as either Fail, Short, Impedence Mistmatch, then you have a Layer 1 issue.
The entire TDR output is showing that the cable connected to the 3750G switch could be of bad quality of simply bad.  Can I ask if you replace this with something else?
Read more of the TDR here:  How To Use TDR
The network card for the IBM printer is a 10/100. Currently it is set to be 10 half, but I have had it set to be 100 full and was getting the same results.
I have replaced the cables from the switch to the punch and from the wall to the printer. I have also tried a different punch with the new cables and the results are the same dropping between 5 and 10 minutes.
The test results for the 10 H on the cable is the following:
TDR test last run on: July 19 11:59:22
                Pair C     28   +/- 2  meters Pair D      Short
                Pair D     28   +/- 2  meters Pair C      Short
I have connected it directly to the switch this afternoon and I am still getting a fail on Pair A...when running it at 100 F I have changed the cable out with a # of cables and the same results. See below:
#sh cable-diagnostics tdr interface gigabitEthernet 1/0/13
TDR test last run on: July 19 16:21:34
(AUTO on switch)
                Pair C     7    +/- 2  meters Pair D      Short
                Pair D     6    +/- 2  meters Pair C      Short
(Speed and Duplex Manual on Switch)
TDR test last run on: July 19 16:26:24
                Pair C     6    +/- 2  meters Pair D      Short
When I have it set to 10 H I get the following results.
(AUTO on switch)
TDR test last run on: July 19 16:30:00
TDR test last run on: July 19 16:32:40
Thoughts?
Also as a note to think about.
I created an isolated network and put the printer on the unmanaged switch with a laptop on the same network. As long as it is not tied into the Company network the printer never drops on the laptop.
Once I introduced the printer to the Company network the IP drops after 5 to 10 min even though the link on the switch shows the connection is up.
  5 minute output rate 17000 bits/sec, 21 packets/sec
     182965 packets input, 39889393 bytes, 0 no buffer
     Received 44267 broadcasts (628 multicasts)
     4546 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     23609643 packets output, 2307349703 bytes, 0 underruns
     1408 output errors, 35 collisions, 4 interface resets
     0 babbles, 228 late collision, 0 deferred
Again this make no sense to me and I am at a lose as to why it works when I isolate it from the network, but drops when it is on the network.
Anyone have any thoughts?
Kris
Just to show you what happens when the printer drops
Reply from 172.16.10.69: bytes=32 time=3ms TTL=30
Request timed out.
Reply from 172.16.10.69: bytes=32 time=2ms TTL=30
Reply from 172.16.10.69: bytes=32 time=53ms TTL=30
Reply from 172.16.10.69: bytes=32 time=89ms TTL=30
Reply from 172.16.10.69: bytes=32 time=86ms TTL=30
Reply from 172.16.10.69: bytes=32 time=84ms TTL=30
Reply from 172.16.10.69: bytes=32 time=60ms TTL=30
Request timed out.
Request timed out.
Request timed out.
Aileron88
I think the best course of action would be to elimate the port on the 3750 as a cause of any issues. Connect the printer to a different port.
If this doesn't resolve the issue it would be interesting to see a 'sh interface xxx' when the printer 'drops' and the output of a 'sh ip arp' when this happens also. Or even the output of a sh logg to see if you have anything going on there. The other option is to create an access-list that references only 172.16.10.69 and debug ip packet against this until it drops.
Adam
Adam,
I switched it to a new port on the switch. I had tried that in the past to thinking I may have a bad port. Just FYI the port never drops the connection from the NIC on the printer and the switch I am always showing and up/up on the port. The only problem is the IP drops and I cannot reach the printer unless I reset the printer power.
The port comes up as you see below for interface stats and the sh ip arp
#sh interfaces gigabitEthernet 1/0/12
GigabitEthernet1/0/12 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 000f.23d8.5d0c (bia 000f.23d8.5d0c)
  5 minute input rate 2000 bits/sec, 4 packets/sec
  5 minute output rate 23000 bits/sec, 22 packets/sec
     2347 packets input, 467967 bytes, 0 no buffer
     Received 1680 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     899264 packets output, 84383316 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
#sh ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  172.16.10.162           0   0014.c240.16c4  ARPA   Vlan1
Internet  172.16.10.230           1   0021.5abd.d335  ARPA   Vlan1
Internet  172.16.10.207           0   3c4a.92ef.856c  ARPA   Vlan1
Internet  172.16.11.54            0   0026.1808.6269  ARPA   Vlan1
Internet  172.16.11.59            0   0023.2431.19b8  ARPA   Vlan1
Internet  172.16.10.16          217   0009.b7cc.8880  ARPA   Vlan1
Internet  172.16.10.17          218   0009.b7cc.7000  ARPA   Vlan1
Internet  172.16.10.26            0   0012.7992.2fa2  ARPA   Vlan1
Internet  172.16.10.10            -   000f.23d8.5d40  ARPA   Vlan1
Internet  172.16.10.8             0   1cdf.0fa6.5d40  ARPA   Vlan1
Internet  172.16.10.83          209   0009.b7cc.7880  ARPA   Vlan1
Internet  172.16.10.91          209   0009.b7cc.8e80  ARPA   Vlan1
Internet  172.16.10.69            9   0080.720b.b486  ARPA   Vlan1
As for the logs the only time that I see the interface drop is when the printer is power cycled.
I am going to create the ACL and run debug. I had not thought to try that just yet, but atleast will provide some information about what is going on.
Thanks again and more to follow as I get the debug logs.
Kris.
