Cisco 3750 High CPU Load
andreribeiro
I'm facing a big issue with my stack of two members os 3750E.
The CPU is so high but there is any process consuming the CPU as you can see bellow.
#sh processes cpu sorted
CPU utilization for five seconds: 96%/84%; one minute: 96%; five minutes: 94%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
90 905211 169354 5345 1.80% 1.54% 1.51% 0 RedEarth Tx Mana
179 1348764 988489 1364 1.47% 1.19% 1.16% 0 Hulc LED Process
134 440167 43981 10008 0.98% 0.90% 0.87% 0 hpm counter proc
13 274848 360295 762 0.82% 0.77% 0.73% 0 ARP Input
229 163220 232279 702 0.32% 0.30% 0.27% 0 IP Input
390 3674 1492 2462 0.32% 0.03% 0.02% 5 SSH Process
247 124654 227296 548 0.32% 0.28% 0.28% 0 Spanning Tree
89 396288 233160 1699 0.32% 0.44% 0.51% 0 RedEarth I2C dri
I checked the CPU queu frames and in 5 minutes the difference doesn't seems unusual (image attached).
On logs nothing special.
Can someone give me an hint here?
Thank you
Model: WS-C3750X-24
Firmware Versoin: 15.0(2)SE11
19 Replies 19
Thank you Leo,
The requested command output is attached.
Sh version is on a reply to Diana above.
As you can see processor now is ok, but during the morning it was like hisotry file attached.
Thank you for your help.
I just checked the output I've requested and it looks like OSPF flapping could be causing the issue of high CPU.
andreribeiro
Additional information.
As you can see the history of CPU load is so high.
CPU history is attached.
Did you try restarting switch ?
did you try to upgrade the IOS - as advised below?
