Cisco 3750 Issue - Multicast
erodriguez27
              Hi, the 3750 version is:
12.2(44)SE5
The OSPF/EIGRP is not working through the 3750.
The sesions is no configured in the 3750 this is just a distribution switch to my customer.
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(50)SE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 26-Mar-10 06:38 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02900000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
DIST-SW-3750-1-HOWA-HOWA uptime is 1 week, 6 days, 6 hours, 57 minutes
System restarted at 02:11:14 EST Sat Aug 3 2013
System image file is "flash:c3750-ipbasek9-mz.122-50.SE4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-48TS (PowerPC405) processor (revision F0) with 131072K bytes of memory.
Processor board ID FOC1225W09X
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
56 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:22:0C:41:E1:80
Motherboard assembly number     : 73-10218-08
Power supply part number        : 341-0107-01
Motherboard serial number       : FOC1224616N
Power supply serial number      : AZS1215036R
Model revision number           : F0
Motherboard revision number     : C0
Model number                    : WS-C3750G-48TS-S
System serial number            : FOC1225W09X
Top Assembly Part Number        : 800-26857-02
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                : COM7X10ARA
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3750G-48TS     12.2(50)SE4           C3750-IPBASEK9-M
     2 52    WS-C3750V2-48TS    12.2(50)SE4           C3750-IPBASEK9-M
Switch 02
Switch Uptime                   : 1 week, 6 days, 6 hours, 57 minutes
Base ethernet MAC Address       : 28:93:FE:D8:B3:00
Motherboard assembly number     : 73-11762-05
Power supply part number        : 341-0328-01
Motherboard serial number       : FDO14130PM5
Power supply serial number      : LIT140505EJ
Model revision number           : E0
Motherboard revision number     : A0
Model number                    : WS-C3750V2-48TS-S
System serial number            : FDO1413Y0NF
Top assembly part number        : 800-31053-02
Top assembly revision number    : A0
Version ID                      : V02
CLEI Code Number                : COMGS00ARA
Configuration register is 0xF
Reza Sharifi
You didn't provide much info, so we can help you.  You start with Multicast and jump in to EIGRP and OSPF.  Can you explain what you are trying to do?
My 3750 is just a distribution switch, when i conect the customers of a area. Some customer are using OSPF o EIGRP but the protocol is not working
CUSTOMER---->3750---CoreWAN--->-----CUSTOMER---->
If i conect the customer to other distribution switch the protocol OSPF get UP.
only happens with this 3750
