Cisco 3750 - Nvram location onboard
Pipa
Hi There,
I'd like to find out the location of the NVRAM location on the 3750s. Can anyone tell me where it is based on the photo of the motherboard? or at-least need to know the location where all the important data(configuration, password, etc) is stored on the motherboard, just need to locate the area where this location on the motherboard of the switch. If anyone can point it out for me that would be great.
NVRAM location or where data is stored?NVRAM location or where data is stored?
Pipa.
NVRAM is part of flash memory. The flash chips (onboard, not upgradable on the 3750) are located next to the processor (in the right part of your picture, in the middle, you have the DRAM to the left of the processor, then the processor, and I think the flash is under the processor)...
Hi Georg,
Thanks for your reply. Are you able to point them out from the photo? Also the flash, you mean underneath of it(underboard)?
Pipa.
I marked the DRAM, processor, and flash (where I think it is)...
Great. Thanks Georg!
