Cisco Nexus 3048 upgrade from 7.0(3)I6(1) to 7.0(3)I7(4) fails to load new-vesion
kalumbi
After what seems to be a successful install of version 7.0(3)I7(4), the switch fails to load. It reboots a then gets stuck on loader>.
Any thought on how I could resolve this issue?
SWITCH# install all nxos bootflash:nxos.7.0.3.I7.4.bin
Installer will perform compatibility check first. Please wait.
Installer is forced disruptive
Verifying image bootflash:/nxos.7.0.3.I7.4.bin for boot variable "nxos".
[####################] 100% -- SUCCESS
Verifying image type.
[####################] 100% -- SUCCESS        -- SUCCESS
Preparing "nxos" version info using image bootflash:/nxos.7.0.3.I7.4.bin.
Preparing "bios" version info using image bootflash:/nxos.7.0.3.I7.4.bin.
Collecting "running" plugin(s) information.
Collecting plugin(s) information from "new" image.
Performing module support checks.        -- SUCCESS
Notifying services about system upgrade.        -- SUCCESS
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1       yes      disruptive         reset  default upgrade is not hitless
Images will be upgraded according to following table:
Module       Image                  Running-Version(pri:alt)           New-Version  Upg-Required
     1        nxos                               7.0(3)I6(1)           7.0(3)I7(4)           yes
     1        bios                        v4.5.0(11/09/2017)    v4.5.0(11/09/2017)            no
Switch will be reloaded for disruptive upgrade.
Do you want to continue with the installation (y/n)?  [n] y
Install is in progress, please wait.
Performing runtime checks.        [####################] 100% -- SUCCESS
Setting boot variables.
Performing configuration copy.
Module 1: Refreshing compact flash and upgrading bios/loader/bootrom.
Warning: please do not remove or power off the module at this time.
Finishing the upgrade, switch will reboot in 10 seconds.
SWITCH#
Version 2.00.1201. Copyright (C) 2009 American Megatrends, Inc.
Press <DEL> or <F2> to enter setup.
        Press  ctrl L to go to loader prompt in 2 secs
Booting kickstart image: bootflash:/nxos.7.0.3.I7.4.bin
CardIndex = 11056
 Couldn't read file. Expected 392e9000 Got ffffffff
 File does not exist, boot failed.
error: Vendor info. Expected 1024 Read -1
loader>
balaji.bandi
1. Try to boot manually with latest OS
> boot  -your new OS,-
once it boot successfully. change the boot variable and try to reload and check if it boot with new NXOS automatically.
More can be found here :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/upgrade/7_x/b_Cisco_Nexus_3000_Series_NX_OS_Software_Upgrade_and_Downgrade_Release_7_x/b_Cisco_Nexus_3000_Series_NX_OS_Software_Upgrade_and_Downgrade_Release_7_x_newGuide_chapter_...
BB
BB
hi thanks for your reply. I tried loading the new OS manually, it still fails
