Cisco 3750 port flow control setting with HPE storage P4500G2 help
timrichards1
hello all
we are hoping someone can help. We have 4 x P4500G2 nodes connected to our core switches and noticed that the Flow control settings on the cisco 3750 switch is different.
We have 2 of the nodes has their ports configured as Flow Control Receive to 'desired' but the other 2 have is set to 'off'. I'm pretty sure they should all be set to 'desired' but I don't know what will happen if I change them from off to desired? will they lose connection to the network? should it be done out of hours? etc
thanks for your help
Reza Sharifi
Changing flow control on the interface may cause a little outage for a very short time. So, it is a good idea to do it during a maintenance window.
