12-09-2011 02:21 AM - edited 03-07-2019 03:48 AM
Hi everyone,
I have a quick query which i need ratified before proceeding. I have the following scenario -
Lets say the ISP has given me the network range 10.10.10.0/26 (we'll assume this is routable on the internet for the purposes of this example) and a default gateway to the internet of 10.10.10.1 within this range. I have configured a public facing VLAN as follows -
VLAN 300
name PUBLIC
int VLAN 300
IP Address 10.10.10.2 255.255.255.252
I have then created a default route as follows -
ip route 0.0.0.0 0.0.0.0 10.10.10.1
With this configured, the switch can successfully route upstream to the internet with no problems.
I have then moved onto the customers and depending on what service they have purchased, I have subnetted the 10.10.10.0/26 range into smaller subnets. See as follows -
Customer A - 10.10.10.4/30
Gateway IP - 10.10.10.5
Useable IPs - 10.10.10.6
Customer B - 10.10.10.8/29
Gateway IP - 10.10.10.9
Useable IPs - 10.10.10.10 - 10.10.10.14
This continues for each customer depending on how many IP's the have purchased. I have then assigned these IP ranges to a customer VLAN and SVI as follows -
Customer A
VLAN 10
name CUST-A-VLAN
int VLAN 10
ip address 10.10.10.5 255.255.255.252
Customer B
VLAN 20
name CUST-B-VLAN
int VLAN 20
ip address 10.10.10.9 255.255.255.248
It is then up to the customer as to what equipment they use and how they NAT or firewall their internal networks. My question to the community would be, is this the mose efficient and approriate method for performing this solution based on the two 3750 switches provided?
Nick
12-09-2011 04:13 AM
Hi Nick,
The above looks fine for me.
Make sure the inter vlan routing working perfect.
And even if each customer use different device (firewall/router) to perform NAT but all requests comes to your STACK only as the default route for the whole subnet defined here and pointing to ISP. So you may need to think about the cpu burden on the STACK.
Please rate the helpfull posts.
Naidu.
12-09-2011 04:22 AM
Hi Nick ,
This will work. but if i understand correctly both are two different customers and merge at your switch.
this can be security concern with intervlan routing ?
If this is not concern then no issues this will work. however think of future customer growth on these switches.
Also in case in furture you have some additional ISP added. say ISP-2 as a backup ISP. this will not scale much
12-09-2011 04:44 AM
Mohammed,
Thanks for the response, yes all 8 customers all different and therefore have to be secure. In order to ensure security I have performed the following -
interface FastEthernet1/0/2
description CUST-B-VL20-ACCESS-ACT
switchport access vlan 20
switchport mode access
mls qos vlan-based
lacp port-priority 1
channel-protocol lacp
channel-group 2 mode active
ip access-list extended CUST-B-VL20-ACL
deny ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
deny ip 192.168.20.0 0.0.0.255 192.168.30.0 0.0.0.255
deny ip 192.168.20.0 0.0.0.255 192.168.40.0 0.0.0.255
deny ip 192.168.20.0 0.0.0.255 192.168.50.0 0.0.0.255
deny ip 192.168.20.0 0.0.0.255 192.168.60.0 0.0.0.255
deny ip 192.168.20.0 0.0.0.255 192.168.70.0 0.0.0.255
deny ip 192.168.20.0 0.0.0.255 192.168.80.0 0.0.0.255
permit ip any any
In order to address the scalability concern, this is a datacenter with an active and primary feed provided by the ISP as a breakout to the internet. There will be no requirement to add additional ISPs.
You mentioned "future customer growth on these switches". What would be your concerns based on the above configuration if the customers were to grow to fill the switch? If this was the case I would simply add to the switch stack. As the gentleman (Latchum) above mentioned, my major concern is with the stack CPU burden, but the acid test and benchmark for this will be when the first few customers go live.
Nick
12-09-2011 04:52 AM
Hi Nick,
As long as you have seperate SVI for each customer and restricting access between them it is fine.
And for now you may not need to think more about your STACK cpu, because the nating part will be done on the customer device (router/firewall) whcih consume more cpu load. So your STACK will handle only router (static default route) so this may not more burden on your STACK.
I have the same kind of setup at one of my data center where I have /23 subnet and all customers (nearly 15) go to internet via this subnet only. But I have 2951r at edge (facing internet) and in LAN I have 4507r.
Please let me know if you need any suggestions or have any concerns.
Naidu.
12-09-2011 05:29 AM
Hi Nick ,
No issues with cpu at this point you have very very kess customer connected as of now
Just focus on customer security related things.
Your above config will work.
A route-map will be very easy for this kind of setup instead of adding / deleting subnets from access-list from each SVI. This will be easy if you use route-maps.
Using route-maps will also help in future in case you add another ISP etc..
You can play much better with route-maps only access-list doesn't allow much flexiblity.
