cisco 3750 QoS - OutDiscard Errors
John Dufour
I have a couple stacks of 3750x 24 port switches, I am seeing a decent amount of Outdiscards on my interfaces. The research I have done indicates this could be a QoS Problem, looked like the buffer ques were set to low... After tweeking them I still see the errors, I removed QoS from the switch and I am still seeing the OutDiscard Errors.  What eles could this be if not a QoS Problem?
QoS Created by Auto QoS Policy............   Here is the out put..
QoS is disabled
QoS ip packet dscp rewrite is enabled
mls qos map policed-dscp  24 26 46 to 0
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
class-map match-all AutoQoS-VoIP-RTP-Trust
match ip dscp ef
class-map match-all AutoQoS-VoIP-Control-Trust
match ip dscp cs3  af31
policy-map AutoQoS-Police-CiscoPhone
class AutoQoS-VoIP-RTP-Trust
  set dscp ef
  police 320000 8000 exceed-action policed-dscp-transmit
class AutoQoS-VoIP-Control-Trust
  set dscp cs3
  police 32000 8000 exceed-action policed-dscp-transmit
interface GigabitEthernet1/0/3
switchport access vlan 50
switchport mode access
switchport voice vlan 90
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
service-policy input AutoQoS-Police-CiscoPhone
match ip dscp ef
  set dscp ef
  set dscp cs3
queue-set 2
priority-queue out
mls qos trust cos
10 Replies 10
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Might be simply an oversubscribed interface.
If buffers are too shallow for your BDP, packets are dropped prematurely.  If buffers are correct for BDP, transient or sustained over subscription will still drop packets (as it should - also too deep queues can be counter productive except perhaps in cases of very brief transient over subscription).
Can you point me into any specific direction on where to look in order to determin if this os in deed the case?
Disclaimer
Posting
Shashank provides good information.  Beyond that, it can be difficult to tell unless you can correlate ingress load to egress load.  If your egress interfaces shows consistent high outbound load, that can be a good indicator, but transient bursts are difficult to actually see without additional instrumentation.
NB: on some router IOSs there's QoS Bandwidth Estimation (which uses Corvil technology) that can provide some insights into microbursts, but not a feature available on switches (to my knowledge).
Shashank Singh
Hi John,
There are several bugs prior to 12.2(53)SE that can show spurious output queue discards (OQD) on 3750 stack. If you are running anything older that 12.2(53)SE, there is a chance that you are hitting a software bug and the OQD counters do not actually mean that the packets are getting dropped. Please upgrade to 12.2(53)SE or later and recheck OQD counters.
If you are running a newer code, and wish to look into oversubscription, check out the following output for the interface dropping packets: "sh platform port-asic stat drop gix/y". This will tell you about  the asic level drops due to oversubscription.
Please rate this post if this helped answer your query.
Shashank
John Dufour
Running version 12.2.(53)SE2
Reading a few other posts I modified the thresholds
Orginal AutoQoS Config
New modified config
mls qos queue-set output 2 buffers 10 10 10 70
(This was because the drops were happening only in queue 4)
Also I changed the buffers
Orginal config   mls qos queue-set output 2 threshold 4 32 72 100 242
new config     mls qos queue-set output 2 threshold 4 3100 3100 100 3200
Hi John,
I see the exact same behavior on almost all my 3750 (none G, G, X, ... types) type switches.  I worked with TAC on it and got the answer that this is a purely "display bug only" and can "be ignored".  I was also told to apply the latest code (15.X) which addresses the issue in the 3750X series.  I tried that with no success.
So I kept digging.  Cisco actually has a guideline / recommended setup for 3750X switches on their website which I find very interesting.  I learned about it during Cisco Live this year and would never have found it otherwise.
http://www.cisco.com/en/US/docs/solutions/SBA/February2013/Cisco_SBA_BN_LANDeploymentGuide-Feb2013.pdf (see page 21, step 9)
I compared this guide to my configuration and noticed the following difference. The default queue settings 3750X generated via Auto QOS look like this:
     mls qos queue-set output 1 threshold 3 100 100 100 400
Here is the same queue setting from the recommendations document (see link above):
     mls qos queue-set output 1 threshold 3 100 100 100 3200
This is similar to your queue change setting from above.  I have implemented this Cisco recommded setting and have seen almost no OutDiscards since.
So thanks for pointing in the right direction. TAC never confirmed this to be the right step to me and did not want me to change the buffers.  I feel safe however after I read this to be recommended by a Cisco configuration guide.
Mike
Disclaimer
Posting
Michael, you realize you're responding to post over two years ago?
In any case, whether the two different threshold configuration you note actually operate differently depends on how the other queue buffers are defined.
If all the buffers reserve all their buffer allocations, none of the thresholds should be albe to acquire more than 100%.  I.e. the 400 or 3200 doesn't matter.
Even if other queues leave actual buffer space to the common pool, unless you carefully configure, unlikely you'll even be able to acquire 400% let alone 3200%.
Cisco's basic documentation on 3560/3750 buffers is somewhat unclear, but if you haven't seen it, there an excellent document in this support forums:
https://supportforums.cisco.com/docs/DOC-8093
Hello Joseph,
Yes, I did realize that the post was original from 2 years ago.  I still wanted to respond to it rather than opening a new case since it describes almost identically what I am experiencing in my environment.  During my internet search for a solution I have come across other posts that started in 2011 but still receive up-to-date posts that describe the same problem like in this post (i.e. http://thwack.solarwinds.com/thread/41782).  The only difference I found is that this post provided a direction with the change of buffers that seems to lead to a solution to the issue.  At least in my case I saw the problem seems to have vanished from all my 3750X switches after I implemented the Cisco recommended setting.
Let me quote directly from the Cisco LAN deployment guide:
Step 9: If the access switch is a Cisco Catalyst 3750-X, 3560-X, or 2960-S, increase the buffers for the default queue. This modification of the global QoS settings improves the ability to handle high bandwidth bursty traffic. In global configuration mode, add the following command:
http://www.cisco.com/en/US/docs/solutions/SBA/February2013/Cisco_SBA_BN_LANDeploymentGuide-Feb2013.pdf, page 21>
Again, this might not work for everybody but in my case I have deployed this now to various independent 3750X deployments across my WAN and it solved the issue with the high amount of OutDiscards I was seeing before.  So I am glad for having found this Cisco LAN deployment guide step.
reading it now, good find.
John Dufour
How can I tell if I am starving out some other traffic, or if I am causing a delay?  Since I created this configuration change the out-discards have been  clean,
