Cisco 3750 Stack issue
Liad Dayan
Hi guys,
Iam having an issue regarding 3750 stack.
Suddenly the switch start to initiate error msg and some traceback.
Allso some ports suddenly stop working and dont forward traffic alltought i can see interface is UP/UP and negotiate to 1000 Gpbs.
here is the output:
*Mar 28 19:55:41: %PLATFORM_RPC-3-MSG_THROTTLED: RPC Msg Dropped by throttle mechanism: type 37, class 14, max_msg 32, total throttled 56559
-Traceback= 533568z 218281Cz 2441464z 2446EC0z 241AFA4z 26D5768z 26CF5DCz
*Mar 28 19:58:58: %SUPQ-4-CPUHB_RECV_STARVE: Still seeing receive queue stuck after throttling (SW-RUB-FL02-3)
this is the version:
/c3750e-universalk9-mz.122-58.SE2
Somone have any idea?
Ganesh Hariharan
Hi guys,
here is the output:
Hello ,
Check the below with clear explanation and a bug hit for this issue.
https://supportforums.cisco.com/docs/DOC-4866
Hope it Help !!
Ganeshh Iyer
This sounds wired since i installed 28 other switches and this is the first switch it happend on.
Allso this might be the problem that cause some port in the switch to work slowly?
I actually can see that the packet per second decrese by 90% when i switch to some ports and when i change back to my port it go back up..
