Cisco 3750 switch routing problem
Marco Bisignano
Hi all, I have a Cisco switch 3750 with this configuration: on Fast ethernet 0 I have configured this network:
interface FastEthernet0
ip address 10.41.105.198 255.255.255.192
this interface is connected to a remote site (remote site address is 10.41.105.1)
then I have configured:
interface GigabitEthernet1/0/1
switchport access vlan 101
and
interface Vlan101
ip address 45.100.11.1 255.255.255.0
now I have a PC connected to GigabitEthernet1/0/1 and  this is the configuration:
IP: 45.100.11.10
Subnet: 255.255.255.0
GW: 45.100.11.1
Now the situation is:
ping from SWITCH 3750 to remote site 10.41.105.1 is OK
ping from PC to 45.100.11.1 (GW) is OK
ping from PC to 10.41.105.198 (FastEthernet0) is OK
ping from PC to remote site 10.41.105.1 is NOT OK (Reply timeout)
why I'm not able to ping remote site on 10.41.105.1 ? I have already tried to set:
ip routing
ip route 10.41.105.1 255.255.255.255 FastEthernet0
ip route 45.100.11.0 255.255.255.0 vlan 101
but is still not working and the answer is the same (Reply timeout); please help me.
Thank you.
Hi!
Then you should not be able to ping from remote site to 45.100.11.1.
This could be caused by a routing problem in the remote site with no route to 45.100.11.1/24.
Hope it helps, best regards!
JC
7 Replies 7
Carlos Villagran
Hi!
Can you ping to 10.41.105.1 from the switch?
Regards!]
JC
Yes ping from SWITCH 3750 console to remote site 10.41.105.1 is OK
try this:
ip route 10.41.105.192 255.255.255.192 FastEthernet0
and test again.
No sorry, absolutely not working
Hi!
Can you ping 10.41.105.198 from PC?
Regards!
JC
Yes, as I reported on my post those are the results:
Hi!
JC
