Cisco 3750 Switch (stacking) Etherchannel Trunking with Foundary Switch
Sunish Nair
I would like to get some information about the Cisco 3750 Switch Etherchannel Trunking with Foundary Switch.
I got following documents about this configuration, if any body done this pls let help me to get configuratoin on the same.
http://subversity.net/etherchannel-trunking-between-a-foundry-switc
http://archives.devshed.com/forums/networking-100/foundry-trunks-to-cisco-etherchannel-1330210.html
http://archives.devshed.com/forums/networking-100/link-aggregation-etherchannel-between-cat-and-foundry-1221294.html
These are the documents i found from the net about this configuration, if it's correct or if any body know how to do this integration please answer on my doubts.
Thanks in adavnce for answering my doubts....
Sunish
Giuseppe Larosa
Hello Sunish,
LACP is standard based 802.3ad so it should be your best choice as described here:
http://subversity.net/link-aggregation-on-cisco-catalysts-and-found
if the C3750 is a stack you can form your bundle using ports taken from different switch members.
for trunking you need to use standard based 802.1Q
int gix/y
switchport
switchport trunk enc dot1q
switchport mode trunk
switchport trunk allowed vlan x,y,z
shut
you need to prepare all the ports before then you can add
verify with sh etherchannel summary and use a free not used group number
int gix/y
channel-group k mode active
then you can activate all the ports using interface range if you want to make a bundle that also acts as a trunk.
in interface range you can give no sh
follow the above link for configuration on the foundry side
Hope to help
Giuseppe
The information contained in or attached to this e-mail contains confidential or privileged information. If you are not the intended recipient, be aware that any disclosure, copying, distribution or use of the contents of this e-mail is PROHIBITED. If you have received this e-mail in error, please notify the sender and delete the e-mail immediately. Thank you.
