Cisco 3750 System Light
Jason Caron
The system light on a Cisco 3750 flashes continually when powered on.
Any ideas?
greg.washburn
If is only flashing amber on the syst light then you post failed and the switch is not functioning correctly. Try hooking up a console cable and see if you get any valuable input from what you see during the load.
