the application of "full-flow" in microflow policing
Eric.Wang
we have two sites A and B. let us say IP ranges are 10/8 in A and 20/8 in B
I want to apply microflow policing on user/server port at site A, so that for this host at site A, let us say
1. allowe 1Mbps to host 20.10.10.10 at site B
2. allowe 1Mbps to host 20.11.11.11 at site B
basically the goal is to police EACH flow at 1Mbps to host range 20.x.x.x. NOT to police ALL flows at 1mbps
should I use key word "full-flow". does it mean each flow is identified as source/dest IP?
access-list 101 permit ip any 20.0.0.0 0.255.255.255
class-map 1m-eachflow
match access-group 101
policy-map per-flow-map
class 1m-eachflow
police flow mask full-flow 1000000 conform-action transmit exceed-action drop
interface range g1/1 -48
service-policy input per-flow-map
so will this work with "full-flow" keyword?
7 Replies 7
Edison Ortiz
In theory, that's how micro-flow policing works. With that said, what type of hardware this configuration is going to be implemented and IOS version?
__
Edison.
12.2(18)SXF3 on SUP720
line card is WS-X6748-GE-TX or WS-X6548-GE-TX
Be aware, when applying policers to a physical port in the 6500, you may run out of agg-ids. Best practice is to use vlan-based QoS but the drawback is that the policy must be the aggregated value of all participating ports.
For information on agg-ids issue, see this technote:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801b42bf.shtml#qm_agg
HTH,
__
Edison.
Edison:
thanks for the tip.
this error is only about Aggregate policers
correct? I am trying to implement microflow policer
some doc says sup720 can support 128K flows and 64 different rates.
what do you think?
The error is misleading. It consumes agg-ids on any QoS applied to the physical port.
You can do a quick test and apply your configuration on 48 ports and then type the command:
show mls qos ip
and look under the Agg-ID column. Once you reach 1023, you are out of luck.
__
Edison.
Edison:
great info. thanks
but other than this trick. my config. looks good for my desired operation???
Yes.
